Hi Guys, here is my 32 4 door manual. Currently not rego, but has been previously. Car has been set up for drift, perfect balance of power, handling and brake mods. Most reliable track car, never missed a beat. I have all the standard parts to return it to stock, this will be included in the sale, makes geting it rwc easy.
Thousands have been spent on it, just take a look at all the parts. Well over 15k in parts.
Other good point is its a personal import, it does not have all that heavy side intrusion bs.
Reason for sale, really want a clean street rego'd 2 door 32.
Price. $10,000 ono for quick sale. Swap for clean r32 2 door.
Engine: Serviced reguarlly, makes 210rwkw on 16psi
· Rb25 GCG Highflow turbo (less then 15000km)
· GCG 14psi actuator
· Sard 650cc Injectors
· Sard Fuel Pressure Regulator
· Z32 AFM
· Custom Intake/cold air AAA Pod filter
· Cusco Catch can
· Adjustable cam gears
· Gates Timing belt
· Gready FMIC
· Splitfire coilpacks
· Turbotech boost controller
- Nisstune ECU
Gearbox/Driveline:
· Rb25 gearbox (less then 80,000km)· Short shifter
· Nightworks Urathane Gearbox mount
· Welded Diff
Suspension/Brakes:
· Coilovers; Buddy Club front, and JIC rear
· Front Nismo strut brace
· CUSCO rear strut brace
· Alloy rear sub frame bushes
· Urathane upper control arm bushes (front)
· DBA 4000 slotted rotors Brand new less then 300km (front and rear)
· QFM A1RM 650 degree hi temp pads, (front and rear) less then 300km
· HICAS completely removed, lock bar and all solenoids and lines removed
Interior:
· Cusco full cage 6 point with harness bar, (currently just running half cage but rest will be included)
· Rear trims + seats removed but will be included
· Drift handbrake button
· Autogauge gauges: Water temp, oil temp, oil pressure, air/fuel and boost.
· Golf Ball shift knob
· Pioneer CD/MP3 headunit
· Pioneer 6x9 rear speakers
· Momo deep dish steering wheel (same dimensions as nardi deep corn)
- Recaro SR (3 or 4 not sure awsome condition like new, genuine with genuine rail)
Body:
- Drift teks 17x9 x4 +35
· GTR Bonnet
- GTR front bar (bit scuffed up)
· Top Secret Grill
· lipped front and rear guards
- guandor side mirors
Stock parts lieing around can be indluded
· Suspension/spair disk rotors
· Stock wing
· Stock trims
· Stock engine parts inc, turbo, AFM, injectors, SMIC
· Airconditon lines/condsor/unit
- Bonnet, front bar, front reo
+ heaps more
In addition to the above, also have the following not installed.
· Grex Oil cooler and relocation kit
· BnM line locker
· R33 stock wheels x2
- R32 stockies x4
Few pictures below...
Damage isnt tooo bad, side skirts cover most the bottom sil damage, rest can be beaten out or boged over. Up to you. Drives straight, chassis isnt bent.I have a set of final Konexxion side skirts I will include in the sale, just need to be sprayed and fitted.
$10,000 ono swaps?
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
