R32 Gtst Lots Of Goodies, Drift Ready, Street Legal..
Hey All,
The time has come, I have to let her go, my growing family requires the money.
The 32 has been a project toy for over 2 years, and I dont want to let her go, But I dont have much choice. I have taken it drifting at QR a few times, and a few times at archy, great car, slide really well considering it doesnt have huge horsepower.
The car has 128,000kms on it, I have only done about 6000 ( yes Six thousands). Since I have had it, I have done the following work to it.
Fresh RB20 went in 10 weeks ago, with new belts, pulleys, gaskets, Cleaned injectors, fuel filter, oil filter, Oils
5 speed manual
17 inch Nismo/ Rays LM GT2 rims, 215/45/17 front, 235/45/17 rears tires are wearing
Tein HA height adjustable coilovers, Rears rebuilt 18 months ago, new seals and thread sleeves,
1.5 way mechanical Diff, locks beautifully,
brand new Heavy Duty clutch plate,
HICAS lock bar, with lines plumbed back to pump,
GTR alloy bonnet and grill
GTR Fibre Glass front bar, skirts and rear spats,
Apexi Pod filter, with custom air box, with Cold air ducting from front bar,
600x300 Intercooler in front bar, cold pipe heat wrapped to stop heat soak,
I have been told its a 33 turbo, but I dont know for sure!
TurboTech boost controller running 13PSI,
60x30mm Serck Oil cooler, with all SPEEDFLOW hoses and fittings, HKS oil cap
Remote oil filter, Speedflow hoses and fittings,
58mm Alloy Radiator, with 12 Inch Thermo Fan, SSR radiator cap
3 Inch Dump back Exhaust, nice and quiet ( never had decibel reading),
Rebuilt Alternator,
Turbosmart Fuel Pressure gauge,
Alloy rear cradle bushes (pineapples),
GTR rear sway bar with Nolathane bushes,
Front Strut Brace,
ABS brakes ( rare on 32 GTsT's,
Fuel Pump hard wired for 14 volts, increased pressure and reduced pressure drop off,
Brand new Century battery last week,
Fresh coil packs, all tested and in great condition,
GTR seats,
Water + Oil temp, Oil Pressure, Boost, and voltage gauges,
Personal Euro Steering wheel,
Brand new windscreen 6 months ago,
Alloy Gear knob,
JVC CD head unit, fusion 6x9s 5 inch fronts
Two Loud Air Horns,
Currently rego'd, with personalised plate, sell with out plates,
May not pass roady due to the diff, so road worthy will be at buyer expense.
Did have leaking ABS unit, so paint on chassis rails below unit has peeled away, had new unit installed a while ago, but I think this one is leaking too ( $200 for a new one),
Selling due to young family, and needing the money.
would like $12,000 for the car, all reasonable offers considered, please no swaps as I need the money not another toy, sorry
Please PM or email to [email protected]
I am located In Ormeau, which is just South Of Yatala ( South of brisbane, north of Gold Coast) In Qld
  • 4 months later...
  • 1 month later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
