also available are some 33 parts guards, doors and spoiler excelent condition
Wrecking 180sx rolling shell, most parts available
lights
doors
guards
interior...
pm if interested in any parts
wanting to get rid of it asap.
https://www.sau.com.au/forums/topic/290417-wrecking-180sx/#findComment-4859922
lights
doors
guards
interior...
You got any side boot trim, centre aircon vent surround, parcel shelf and or the knobs on the boot that hold up the parcel shelf? and what is the condition of the dash?
Cheers
https://www.sau.com.au/forums/topic/290417-wrecking-180sx/#findComment-4861001
Hey
got all of the side boot trim, havnt got air con vent or parcel shelf the dash has a crack in it but the knobs that hold the boot are still there and arnt broken.
Cheers
https://www.sau.com.au/forums/topic/290417-wrecking-180sx/#findComment-4861045
