check this out guys...finished changin my oil yesterday and decided to take it for a quick spin up and down westall rd. came back in 5 mins went in the house and my lil sis says theres a hissin sound commin from the tyre. went out had a look, stuck my finger in and found this.
am i lucky or what that this didnt pop when i was on the freeway?? waste of a perfectly good tyre:D anyhoo's dont know squat about tyres, any recomendations for decent affordable tyres(for stock rims). should i go out and replace the other rear tyre aswell?? now wheres that bloody thread gone for cheap tyre places in melb:D:D
https://www.sau.com.au/forums/topic/29065-lucky/
no its not usual is it. theres no camber on the car ...its stock ride height. just strange also taht its only happened to the left rear wheel. the right is fine.
another theory is that i might have got a flat spot on that part a while back...and over time its just gradually broke apart
so should i replace the other rear tyre also?? the tyres are nangkang by the way.
https://www.sau.com.au/forums/topic/29065-lucky/#findComment-597110
That is not a good look! you may want to try second hand tyre places as well, you never know what you will find. you should replace both rears as tyres should match left to right. there is a second hand tyre place on abbots rd in dandenong south if that's any help. :)
https://www.sau.com.au/forums/topic/29065-lucky/#findComment-597183
Hey If i were you I wouldnt get 'cheap' tyres..
Think about it.. tyres are the only thing keeping you on the road, and with skylines they have quite a bit of power on tap, and by the sounds of it you like to use it, which isnt a bad thing, just as long as youve got the equipment to do it safely! Tyres are the best place to start.
It really gets me vented when people ask for cheap tyres.. they are one of the most important safety factors of ANY car.. Ive seen enough cars come off the road and into a tree because of bad tyres..
Is YOUR life or your friends lives worth saving a measly 100-200 bucks? Id like to think not.
Spend the extra dosh.. and feel a bit safer on the road.
https://www.sau.com.au/forums/topic/29065-lucky/#findComment-597621
extatic - yeah your absolutely right about that mate. when i mentioned cheap i didnt mean cheap and nasty per-say but more along the lines of decent and afordable. i remember seeing a thread before the data loss about discounted/cheap tyre places in melb...thats where the word cheap came in:D:D
strutto - yeah ive only tried handbrakies about 4 times in the wet....couldnt get a hang of it so i gave up. handbrakies should produce flat spots on both tyres....but not in my case.
R34GTT - i sense a hint of sarcasm there...hehe. yeah ive had these ever since the car landed and was complied which coincidentaly is about 3yrs now:D:D trust me...theres no camber!!
Autotrust- thanks....second hand tyres are an iffy for me...might appear good but u just dont knwo the history of it. but ill definitly be checkin it up when its time to go to those full-lock classes next yr:D:D
https://www.sau.com.au/forums/topic/29065-lucky/#findComment-597642
ahk cool mate, just make sur eyou stick with known brands.. and dont get sucked into the crappy ones like nankang, austyre etc..
Big names like Michellin, Bridgestone, Good-Year, Pirelli etc.. all produce top quality tyres.. jump on performanceforums and do a search, theres lots discussed there.
https://www.sau.com.au/forums/topic/29065-lucky/#findComment-597664
haha...yeah..when i first saw these on my wheels instead of the potenzas that were originally on there before compliancing..i was like wtf??nangkang what the hell is that!!
anyways went shoppin around and found myself some kummo's and tornados for around $140bucks each they are both silica based too which is good i think. i assume these are decent brands yeah??
https://www.sau.com.au/forums/topic/29065-lucky/#findComment-598730
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
