If they were still available new i would consider making an offer Femno but if i ruined one on the track I would be stuck with 3 wheels.
Free bump for some drop dead gorgeous wheels tho mate.
2 q's mate:
- do you know the approx weight of each rim (i know there was a spreadsheet floating around somewhere which includes this info across every rim on the market)
- are they forged or cast?
The rims and tyres together weight 25kg, I know that much. The tyres are pretty wide so they would contribute to a fair chunk of that.
Being a 2 piece rim, of which the centre has a machined finish front and back, my guess would be cast centres.
i reckon you would be safe to assume forged.
how on earth these wheels have not been sold yet, i got no clue.
i told timmy if i wasnt spending all the money on the engine i would have snapped these up in a heart beat.
good luck matt, but u wont need it for a tough looking rim like that.
BAH Russell what would you know.
I now have a set of Rays 57s Pros. They are sexy ass rims, just like these ones.
Cheers for the kind comments guys.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
