hi guys,
i am selling all the parts that i have lying around for a R33 GTS Skyline
1. Custom Plenum Creation Custom made plenum. completely untouched and BRAND NEW!!
Asking for $850.00 - Firm.
2. R33 GTS Series 2 front bumper bar with the M Spec extra lip - Original Plastic Item. few small cracks on the lip which can be repaired. selling CHEAP!! Asking for $500.00
3. R33 GTR series 1 - Blue trim - rear seat only. few small cigarette burns on the bottom part of the seat. Top part in perfect condition. Not much sun damage on the seat at all like some others i've seen. Asking for $250.00
4. OZ Audio - Matrix Elite 10" Dual 2-Ohm Sub Woofer 1400W. this is a great sub woofer for any car. this sub was bought new and never used - still in original packaging. Asking $450.00
5. JL Audio Sub woofer - 12" W3 Dual 4 Ohm. This sub has been used on and off for a few years. this sub has an awesome sound and would suit any car. Asking $200.00
Local Pick up from south of Sydney for the rear seat and front bumper bar. Can post the plenum anywhere in Australia. PM me your location and i will let you know how much to post.
contact me by sms or PM me on here - 0403 313 097
thanks
Edited by MATT_R33
https://www.sau.com.au/forums/topic/290767-r33-parts-and-audio-items-for-sale/
hi guys,
i am selling all the parts that i have lying around for a R33 GTS Skyline. Please note PRICE DROP - 15/10/09
Asking for $750.00 - firm
2. R33 GTS Series 2 front bumper bar with the M Spec extra lip - Original Plastic Item. few small cracks on the lip which can be repaired. selling CHEAP!! Asking for $400.00 negotiable
3. R33 GTR series 1 - Blue trim - rear seat only. few small cigarette burns on the bottom part of the seat. Top part in perfect condition. Not much sun damage on the seat at all like some others i've seen. Asking for $200.00 negotiable
4. OZ Audio - Matrix Elite 10" Dual 2-Ohm Sub Woofer 1400W. this is a great sub woofer for any car. this sub was bought new and never used - still in original packaging. Asking $450.00 negotiable
5. JL Audio Sub woofer - 12" W3 Dual 4 Ohm. This sub has been used on and off for a few years. this sub has an awesome sound and would suit any car. Asking $200.00 negotiable
Local Pick up from south of Sydney for the rear seat and front bumper bar. Can post the plenum and subs anywhere in Australia. PM me your location and i will let you know how much to post.
thanks
come on guys. no one wants any of this stuff at all??? surely there are some takers?
surely someone is interested in some of this stuff??
i also have for sale:
1. R33 GTR FRont adjustable strut brace - original item, not a copy $100 pick up
2. R34 GTR rocker cover garnish - brand new $100 pick up only or + postage to wherever you are.
just ask if you need to see picks. i should be taking some over the next few days.
taking offers on all items for sale. everything still for sale.
taking best offers. need this stuff gone. can anyone help me out with modifying the first page of my post to reflect the dropped prices that i am asking?? not sure if i can do it.
also have for sale:
1. R33 GTR complete rocker cover set - all 4 pieces. they do needs to be stripped and repainted. $400.00
Edited by MATT_R33
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
