if uve got the do$h then do the whole zaust system , extractors back its worth it if u can afford it, if not a cat back is fine.
Dont go higher than 2.5 inch and dont go lower than 2.1/4 inch not worth it.
To avoid attention from the boys in blue dont get a fat, angled cannon, a simple twin tip will suffice, plus it looks stock.
Heat wrapping or heat coat the headers either or both, depends how fussy u are.
You will be able too feel a difference from your new system, makes the car feel alot more responsive
if u are in the sydney area google 'best mufflers', 'liverpool exhaust' and 'tuffy mufflers' ring around and get some quotes
and lastly, enjoy your ride :D
here is my input, Just put a decent filter Pod/Panel and just go a cat back. dont waste your time/money
as i have a r33 s1 gts and thats all i have, yeah its no race car but hey thats what u get for being on your P's these days.
just stick it out and save for a turbo conversion OR sell and get a turbo car.
" catback with pod still beats most 6's and 4 "
Here is what i have done since you cant do power mods.
i got my stock r33 and added what i could eg,
bodykit inc - Trust front bar / Vs side skirts / Vs rear bar / Carbon fibre bonnet.
18" chrome wheels, Super low king springs, Exedy racing clutch, 2.5" cat back exhaust.
stereo, painted my brakes, got some axs seat covers, painted plastic interior parts.
basically anything i could to keep me satisfied.
BUT now...
come december 8th im off my P's and i already got my shopping list together,
DONT bother upgrading your n/a engine to turbo "been there done that" its so much easier to swap and drop and u know it will run properly!
u just go get your rb25det motor from an auto wreckers and put that in with a wiring loom and ecu.
Anyways here is what im doing now for my conversion,
- $1800 Rb25det Engine + loom
- $1300 Apexi Pfc w/Hc
- $130 Turbosmart Dual Boost Controller
- $399 JustJap FMIC
- $110 Sard FPR
- $245 Bosch 040 Fuel pump
- $350 Z32 AFM w/Adapter
- $1174 Varex adjustable cannon - 3" piping - 3" highflow cat
- $633 GFB Deceptor Pro Bov
- $600 Dyno Tune
Total = $6471 ( ide like to upgrade injectors but will do when i get my plenum and fuel rail done / when i save :banana: )
Brakes! yes u should upgrade your 4stud to 5stud and get turbo brakes to now stop this powerful build of RB,
Correct me if im wrong, but i think u can just upgrade your rotors and brakes on the 4stud which would be cheaper
and it will still do a great job of slowing your new built RB down.
YES! some will say what a waste of money sell it and get a turbo model!
I Think! just save your money for the next 3yrs on your P's and u will have the turbo car u want.
"I dont know if anyone feels the same but i dont wanna see someone else driving around in the car i built"
so as i said i built up my looks/exterior of the car how i like it while i was stuck on my P's,
and since i was stuck for 3yrs i saved up money and now i will have the performance aswell.
Oh and just so u know how much power i was putting out with just 2.5" catback and a pod filter,
"i had injector problems thats why i had it dyno'd"
and i got a power rating of 110rwkw with the blocked injectors, so i was happy with that.
sweet, my fully reconditioned engine is at 167kw with a pod and heat shield. But then again i dont drive it much now that i hit a wall because semi slicks are the devil!!!
I agree with you for not getting rid of your car. Its still yours and going to be a turbo and everything will be the condition that you know because you have had the car for 3 years and its not to expensive so your thinking smart......As for brakes the NA brakes are fine you just need a really good pad (changing the caliper should be better but from what i have heard people say there is almost no difference with the turbo pads to the NA pads :thumbsup: )
If you get good pads then the rotors are even more important and if you want to stay 4 stud you will have to order r33 GTST rotors from DBA but ask the engineers to drill the 4x114.3 hub bolt holes. It can be done because i work at supercheap and plan too get some nice 4000 series from them.
Handling is the way to go!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Just get a heat proof coating and wrap them if you must.
That won't look stock though.
With a heat shield obscuring vision, a cop looking under the bonnet will not be able to tell its not stock.
  • 5 months later...
Hey people i finally got my system done, (yes i know lagged heaps haha) but i went to Liverpool exhaust and got a stainless steel 2.5inch straight through exhaust and ceramic extractors :D car feels so much more responsive now (would like to know the power gains though), sounds unreal. It set me back abit but all worth it if you tell me.
cheers
cheers
aw yeah man thats good as..
how much did it set you back all together?
yeah man :cool:
i know it seems expensive but since i got it with stainless steel it set me back $1800, but worth every cent
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
