I need some assistance on selecting a proper fitted Turbine Wheel and Housing for a mild RB26 that was just built for a mates 32. I'm a 2J kinda guy and know what works best for Supra's. I've tuned a few RB's, pulled a few motors, and had my hands in/around them enough to get an idea, but I've never picked a proper suited turbo for one. I don't know what the engine flows, which makes it difficult. I figure you blokes would know tons more than myself.
The turbo is a CompTurbo TBB T70. T4 divided on a custom stainless header with a TiAL 60mm gate. 18-20 psi on USA crap 93 octane, and 30(ish) psi on VP C-16.
No real power goals in mind. Main goal is to avoid surge, but keep the housing small enough where it'll still spool relatively quickly.
The turbine wheel options we are looking at are Q trim (2.7" exducer), MX trim (2.8" exducer) and SX trim (2.95" exducer).
The housing options in mind are .84 A/R divided, and 1.00 divided.
I have the 4376 TBB with a .84 Q trim on my Supra and I LOOOOOOVE this turbo (Had many turbos prior)
Here's a link for more info.
Comp Turbo CT4370
Thanks again fellas.
He'll want to run the 2.7" 0.84 with a 3.5 or 4 inch vband.
It'll be making about 1 bar of boost at 3500rpm and he should net 600-650 hp on the c16. Probably only 20psi of boost it'll come in at 480hp at the wheels
Personally I prefer to use a Garrett made turbocharger because if you pick the right ones they work better than a pile of parts put together by a reseller .
Garrett often make available compressor and turbine maps but they mean zip it the wheels aren't used in their native Garrett housings . Accurate turbine maps need a set pair of compressor and housing to mean anything because how the comp end loads up the turbine has a lot of say in its performance .
It would be good to know what you're intending to use for an exhaust manifold because that sets the flange size and single/twin scroll options .
GT series turbines and compressor wheels are mostly better things than their older T series cousins because they tend to be lighter and slightly smaller in diameter for the same gas flow .
Once you get into GT35R's (GT3582R's) you tend to be stuck with single scroll T3 flanged turbine housing though Turbonetic make a "F1-35R" based on a larger center section and T4 flanged twin scroll turbine housings .
For someone in the States you could speak to Geoff Raicer of Full Race Motorsport because he's put a bit of time into turbos and manifolds for Nissan RB26's , not cheap but I believe the results are real good .
Cheers A .
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
