comp test isnt 100% accurate and i did also say i used the workshop comp tester which has been known to read lower. either way.. it goes hard. i have no issues with the motor so far. BTW what are the CP's you have for sale for the neo?
Yes pistons are for a Neo engine.
I just thought it was abit weird my engine(neo) was reading significantly lower than than an RB26 which was tested on the same gauge.
i could be interested... need to assess my finances.. PM me with a price for them if u can.
I fitted my GTX today...
a read can be found here http://simonmichelmo...ing-new-gtx-up/
Hey champ, when is the Dyno happening?
What is different about the nuts you used on the turbo??
nah these arent the off centred ones.. they have a slit at the top or crown of the nut and as you tighten them up then deform and lock into the thread... and yeah everyone should beusing them but i havent been :S
as for dyno will be another week away... got heaps of shit i need to do to the car before its down back on the ground.
for now.. heres some things to check out.
Driver profile for WTA
http://www.tectaloy.com/tectaloy_tdc2011_dp_sm.html
Ah ok, do you find they are better or worse than the ones I'm talking about?
Also what did your neo set you back when you bought it?
paid 1500 for the neo...was mising the turbo but everything else there. not bad for a cheap motor!
these nuts are so much eaiser to put on... they go like a nylok nut.. so single use item only really.
i think they are called Crimp nuts. atleast thats what i ask for when i got to my local nucts and bolts. they are the ducks nuts for keeping turbos on.
bargain, I'm picking a neo up for 1900 this weekend, bare motor as well. Still it is the only one I've found for under $2k and in Adelaide in the last 2 months.
Where do you get the nuts from? I need to get some new ones so if they are easier to put on I'll grab them instead.
you in adelaide rolls? i never knew.. if you need a hand with anything or wiring related hit me up.
nuts from MTQ.. pretty cheap!
got my WTA confirmation!
http://www.worldtimeattack.com/index.php/south-australian-g1-champion-simon-michelmore-confirmed-for-tectaloy-drift/
Yeah I'm in good old Adelaide, already converted the 32 to a 33 25, but putting a neo in as it shit itself so hopefully will just be the CAS plus I need to rewire and that's it!
Cheers for the offer. :)
edit: Didn't realise you used rsr's on the car, that must cost an absolute fortune with drift!
Edited by Rolls
  • 3 weeks later...
update: Garage7 repaired my BC coilover and Hoey are regassing it for me.. with some luck i'll have it in next few days.
started mounting my air vent... as typical i cut the hole too f**king big :( oh well this front bar has a limited life span anyway... my painter cant paint it before matsuri so i rattle canned it lol.
Hey rolls, are you going to use the 33/32 loom/ecu/ign set up to to run the 25 neo? what are you going to do with the CAS? is it as simple as a plug re-wire and use the neo CAS or do you have a mechanical solution to put the rb20/ r33 rb25 CAS into the NEO?
Cheers
Justin
I am using all R32 loom up to the ignitor, I chopped the old plug off and used the R34 coils that have the ignitor built in and wired a nice new deutsch plug on the end removing the ignitor, plug looks better than factory! about $35 for all the pins etc but I know it will last forever now.
Using rb20det R32 ecu with a nistune module, R34 cas rewired (pin out is different) 1-4 2-3 3-4 4-1, Z32 afm and S1 r33 intake manifold with aux air valve, throttle body, tps etc. Basically looks like S1 rb25det everything with r34 coils.
Try and get a complete R33 intake/fuel setup etc as the r34 sensors etc are all different, different coolant lines etc, different fuel rail and injector loom, so have no idea how it would all mount up.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
