I've been thinking maybe i want some eyelids for my car but not sure about the ones on ebay. I like the look of these ones (attached) but never seen them for sale anywhere...can someone help me out on where to find these or does someone make them perhaps. I really like the fact they go to the bottom corner of the light and not just straight across.
Thanks
https://www.sau.com.au/forums/topic/291422-eyelids/
the only thing i don't like about the ebay ones is they make it the car look 'sleepy' where as these have a more of an agression look to them. but this is not the only car i have seen them in other photos, what would be involved in making a set?
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4876408
I have these that I have taken off and are lying around. Obviously they are silver made of fiberglass and can be attached with silastic.
I know they are not exactly what your after but PM me if your interested in them and we can arrange something.
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4876727
i want them because the top of my headlights are slightly damaged, and this would cover them, i have the same front kit as that GTR and looking at getting a vented bonnet. I'm trying to make the car look different cuz too many ppl do the same thing.
I agree with all bout making the car look clean as i am very fussy with what i put on my car. No stickers, none of this black and white 2 tone. If it looks off then it won't be going in/on the car.
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4882246
Ok, well I've been working on a kind of Eye-lid project for a few weeks on my 33 GTR. I don't mind the front of the headlights but just think the sides don't look as good as say the R34 or silvia/s200 headlamps because the sides just droop down.
Since the R33 sides are so big, I thought OK I will make some "Side Lids" to reshape.
After lots of paint issues getting paint to stick to aluminum, here is one side done. I have to say it didn't turn out the way I thought it would when I visualised it in my mind. So I'm looking for honest critique here. Does it make them look better or does it just make me look like a tool trying too hard. Be honest, I can take it.
post-16200-1255846189_thumb.jpg post-16200-1255846220_thumb.jpg post-16200-1255846267_thumb.jpg
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4886407
not really much involved, glad wrap a headlight and apply the fibreglass to it. let it dry off and then take them off the headlight. final shape them with a grinder and paint to suit ur car.
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4886579
Not a bad attempt. But it looks like something that belongs more on a prelude/civic/lancer... My GTR is almost identical and it had the normal eyelids on it when I got it, but after sanding back and cleaning up the headlights from yellow haze it looked alot better with them off. Good work at having a go though.
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4886580
Yeah, well I pulled it off this morning before I drove to work. Thought I'd look at it with a fresh outlook in the morning and well - it just doesn't give the effect I wanted.
Maybe will try some angel eye highlights instead.
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4888224
its a matter of personal preferance i guess. i got them to be different as i havent seen one getting around my area with them. im fitting them when i repaint the car to give it a while new look. mine dont go the whole way down the side of the light i think they look lame mine just go back to the edge to a point
so if you like them really does it matter about others opinions?
https://www.sau.com.au/forums/topic/291422-eyelids/#findComment-4914309
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
