I selling up several R32 GTR and Gts-t and Gts performance parts that I no longer require. All located in Adelaide.
All parts are in Great condition, as you'll see from the pictures.
1. A custom made R32 GTR and Gts-t Half Roll cage made by Clinton Ahrns of Ahrns Handling Equipment here in Adelaide. The Cage has harness mounting points and will include 2 near BRAND NEW Sparco 4 Point Harnesses.
post-15679-1255346043_thumb.jpg post-15679-1255346091_thumb.jpg post-15679-1255346139_thumb.jpg post-15679-1255346209_thumb.jpg post-15679-1255346250_thumb.jpg $1100 ono
2. Japanese made Wheels (not sure what they are), 17*8.5 and 17*9.5 with GTR offsets. Re Sprayed in 2-pak Black with a heavy Gold Metallic and Clear Coated. They are also Multi Stud Pattern - 5 x 114.3 and 4 x 114.3. Will come with a Pair of Toyo Teo tires in good condition 85%.
post-15679-1255347418_thumb.jpg post-15679-1255347475_thumb.jpg post-15679-1255347551_thumb.jpg post-15679-1255347613_thumb.jpg post-15679-1255347698_thumb.jpg post-15679-1255347750_thumb.jpg $1500 ono
3. Set of R32 Gts-t Bilstein Coilovers with Custon RS*R Springs. Genuine Bilstein suspension will be an upgrade to any R32 and is made in Germany. Will be a better product and no doubt last londer than any of the cheapO Chinese junk for sale at the moment. All seals are in great condition and show no signs of leaks. $1050 ono
post-15679-1255348685_thumb.jpg post-15679-1255348707_thumb.jpg post-15679-1255348726_thumb.jpg
4. Whiteline Front 24mm Adjustable R32 Gts-t SwayBar. Whiteline swaybars are a Solid replacement for the standard Hollow units and will Defiantly improve handling. $220
5. Modified R32 Gts-t Kakimoto Racing 3inch Exhaust including a DeCat replacement pipe made by Exhaust Technology. I've had the entire center muffler section replaced to increase flow and the volume of the exhaust. Work was done by Exhaust Technology here in Adelaide. Heavily Polished Tip and End $400
post-15679-1255349928_thumb.jpg post-15679-1255349984_thumb.jpg post-15679-1255350006_thumb.jpg
6. Replacement Apexi Panel Filter to suit R32 Gts-t and I'm assuming other cars still running the stock air filter box. $50
I can be contacted by PM or SMS on 0438 86 08 07 and would prefer local sales only.
Cheers
Edited by R32Dreamer
https://www.sau.com.au/forums/topic/291723-r32-parts-gtr-gts-t-and-gts/
Hi,
Re the cage,
  • does it meet CAMS Schedule J specifications?
  • was is custom made to fit a gts-t and happens to also fit GTR, or the other way around?
re the harnesses
  • how wide are the straps?
  • do you know if is it possible to use them with stock GTR seats or do you nee aftermarket items?
Would also be interested in reason for sale, or is that implied in your sig?
thanks
Edited by semislickR32
Hey,
The Cage was not made to Cams specs as far as I know but i would take a guess that it would easily exceed the strength requirements etc. to do so. I've lost my CAMS booklet so CAMS Schedule J specifications means nothing to me at the moment, sorry. If you were to come and take a look at the workmanship and materials used you would appreciate what i mean by "easily exceed the strength requirements".
The Cage was made for a Gts-t but will fit both as I have A Full Safety 21 GTR cage in my Gts-t.
The harness straps are 3 inch wide for that improved safety and comfort and you can defiantly use them with stock seats as I've been using a TRS Harness with my GTR seats. Just run the harness' to the mounting points on the cage or to eyelet bolts screwed into where your rear seat belts bolt into.
Hope that helps, Cheers
Sorry forgot reason for sale, I'm using my full safety 21 cage and I already have a set of TRS harness in black which I'll use... All these parts came with an amateur drag racing R32 Gts-t putting out 340RWKW (built rb27 ;) ) which I've bought.
The spring rate of the Bilstiens is 8kg/mm and 6kg/mm front and rear. This was near purfect in my R32 with a standard front swaybar and a GTR rear swaybar... I post up some pictures of the cage installed tomorrow when I get a chance :)
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
