I selling up several R32 GTR and Gts-t and Gts performance parts that I no longer require. All located in Adelaide.
All parts are in Great condition, as you'll see from the pictures.
1. A custom made R32 GTR and Gts-t Half Roll cage made by Clinton Ahrns of Ahrns Handling Equipment here in Adelaide. The Cage has harness mounting points and will include 2 near BRAND NEW Sparco 4 Point Harnesses.
post-15679-1255346043_thumb.jpg post-15679-1255346091_thumb.jpg post-15679-1255346139_thumb.jpg post-15679-1255346209_thumb.jpg post-15679-1255346250_thumb.jpg $1100 ono
2. Japanese made Wheels (not sure what they are), 17*8.5 and 17*9.5 with GTR offsets. Re Sprayed in 2-pak Black with a heavy Gold Metallic and Clear Coated. They are also Multi Stud Pattern - 5 x 114.3 and 4 x 114.3. Will come with a Pair of Toyo Teo tires in good condition 85%.
post-15679-1255347418_thumb.jpg post-15679-1255347475_thumb.jpg post-15679-1255347551_thumb.jpg post-15679-1255347613_thumb.jpg post-15679-1255347698_thumb.jpg post-15679-1255347750_thumb.jpg $1500 ono
3. Set of R32 Gts-t Bilstein Coilovers with Custon RS*R Springs. Genuine Bilstein suspension will be an upgrade to any R32 and is made in Germany. Will be a better product and no doubt last londer than any of the cheapO Chinese junk for sale at the moment. All seals are in great condition and show no signs of leaks. $1050 ono
post-15679-1255348685_thumb.jpg post-15679-1255348707_thumb.jpg post-15679-1255348726_thumb.jpg
4. Whiteline Front 24mm Adjustable R32 Gts-t SwayBar. Whiteline swaybars are a Solid replacement for the standard Hollow units and will Defiantly improve handling. $220
5. Modified R32 Gts-t Kakimoto Racing 3inch Exhaust including a DeCat replacement pipe made by Exhaust Technology. I've had the entire center muffler section replaced to increase flow and the volume of the exhaust. Work was done by Exhaust Technology here in Adelaide. Heavily Polished Tip and End $400
post-15679-1255349928_thumb.jpg post-15679-1255349984_thumb.jpg post-15679-1255350006_thumb.jpg
6. Replacement Apexi Panel Filter to suit R32 Gts-t and I'm assuming other cars still running the stock air filter box. $50
I can be contacted by PM or SMS on 0438 86 08 07 and would prefer local sales only.
Cheers
Edited by R32Dreamer
https://www.sau.com.au/forums/topic/291723-r32-parts-gtr-gts-t-and-gts/
Hi,
Re the cage,
  • does it meet CAMS Schedule J specifications?
  • was is custom made to fit a gts-t and happens to also fit GTR, or the other way around?
re the harnesses
  • how wide are the straps?
  • do you know if is it possible to use them with stock GTR seats or do you nee aftermarket items?
Would also be interested in reason for sale, or is that implied in your sig?
thanks
Edited by semislickR32
Hey,
The Cage was not made to Cams specs as far as I know but i would take a guess that it would easily exceed the strength requirements etc. to do so. I've lost my CAMS booklet so CAMS Schedule J specifications means nothing to me at the moment, sorry. If you were to come and take a look at the workmanship and materials used you would appreciate what i mean by "easily exceed the strength requirements".
The Cage was made for a Gts-t but will fit both as I have A Full Safety 21 GTR cage in my Gts-t.
The harness straps are 3 inch wide for that improved safety and comfort and you can defiantly use them with stock seats as I've been using a TRS Harness with my GTR seats. Just run the harness' to the mounting points on the cage or to eyelet bolts screwed into where your rear seat belts bolt into.
Hope that helps, Cheers
Sorry forgot reason for sale, I'm using my full safety 21 cage and I already have a set of TRS harness in black which I'll use... All these parts came with an amateur drag racing R32 Gts-t putting out 340RWKW (built rb27 ;) ) which I've bought.
The spring rate of the Bilstiens is 8kg/mm and 6kg/mm front and rear. This was near purfect in my R32 with a standard front swaybar and a GTR rear swaybar... I post up some pictures of the cage installed tomorrow when I get a chance :)
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
