  • Replies 14.2k
yo jack ive got the ones at the front
just not up the side on the panels
Haha i knew you didnt know what i was on about when i messaged you earlier. Name your price dude and ill take em.
At this point 2 is better then none haha.
Edited by Jack88
i did mine at the track today.
with a rubber mallet.
turned out fine.
no cracks, no warps, no deformation.
perfect.
... ugh. homo.
You wish Dave.........and you'd be first on my list :)
i lost over 5k in parts on Sunday night when someone broke into the workshop!
what got stolen
arias 40 thou pistons
spool I beam rods
apexi air filter
hks manifold
acl race bearing kits
all my gaskets including the thicker head gasket
2540 turbo
arp head studs
basically everything that was going into the build got jacked so if anyone see's some of these parts for sale give me a heads up because it'll be a bit sus when someone is selling all these parts but also the tools were stolen like all the snap on stuff! torque wrenches etc
Holy shit man! Really hate hearin g when this happens to a build project. Hope you manage to get it all sorted and catch the low lifes.
Best of luck with it man
It's not related because it's a long way from Hendon, but there seems to be a lot of this going on.
This bloke got knocked off twice ina number of weeks.
http://www.nissansilvia.com/forums/index.p...howtopic=410419
Sucks to hear about all the thefts :bunny:
Lol @ AFT... what a bunch of cockstains! :)
yeah the cops said this has been happening to a few workshops! but at ours they've jacked a few things from our owned cars while left outside behind the big gates like sound system and so on but this is the first time they got inside the shop and they only seem to target performance cars
insurance is covering the tools and and workshop belongings but only up to 5k with customers cars
Word travels pretty quick in the performance parts market, i really hope you and the guys at the workshop fin them before the cops do. Hopefully Son a customer might hear of something from somewhere.
Anyone know what the hex type key used on the R33 GTR wing blade is called?
It should either be a normal Aleen Key, or a Torqx bit Steve. Head to GRH Supplies at Wingfield, guys there should be able to find something to match
On another note, the 33 drove off half hour ago. Happy driving Luciano!
Thanks James, Torx it is :down:
Don't really understand why nissan used this considering the adjustable part uses standard hex bolts
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
