  • Replies 14.2k
really ghetto initially. basically got L brackets from bunnings and bolted them to the seat. then where they lined up on the rail, drilled and bolted them on
make sure u get strong ones though
I'll race ya with the nitro R32 up to 50km/h, it could go up faster but launch is super quick due to it's light weight AWD making it a quick win :cool:
electric is faster :bunny:
I was running a mamba brushless combo and a 3s lipo and was seeing speeds around 100kph with foam tyers. Im also running a Team losi truck with a Sidewinder 5700kv combo and 2s lipo and im hitting speeds around 70kph with offroad tyers.
Quick update on the 26.
The loom is off the motor, aswell as the plenum. Need to organise a small crack in the plenum to be welded up and then strip it down with paint stripper and get it looking like new. Will be replacing all hoses with black silicon ones and getting new intake gaskets.
I picked up the rc car with the S15 shell at hobby habits on main north, the 34 shell at hobby habit daws road and the 32 shell on ebay, I also got an R34 shell that my girlfriend painted a charmeleon purple green colour lol I so wouldnt mind them 1:10 scaled Work Meister or XSA mmmmm
Dave, I was originally going to go for another electric and eventually whack a mamba max in there but couldnt resist trying out the nitro - the noise and the smoke is awesome. I could whack a mamba into the associated 1:18 I got but searching around apparently it doesnt stay on the ground because its too small/light :cool:
That R32 shell only just came in the mail today so its fresh and clean... and then it'll just end up like my S15 shell after it's first tank lol
the middle R34 shell will go on an electric one eventually :rofl:
Did you get your models from Hobby Habit?
also..just dial in some camber..always fun there!
thats it there..on the camera phone.
haha me, scott and adrian have 1:10 electric drift cars, farkin fun, havent taken mine out of the shed in a while tho. I have a 32 gtr shell, Blitz R34 drift shell, AE86 panda spec shell and an S15 :(
Whatever you do, grease up the driveshafts, the front ones are farking expensive!
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
