  • Replies 14.2k
Anyone who says that semi's are no good on the street really have no idea what there on about. Matt (Whatsisname) has them on his car and he cant believe how good they are either.
I'm thinking it's time for semi's on the street, t1r's are struggling, i'm guessing the ku36's are so cheap because there shit?
Ive looked up the thread on here about the special coating thats on them. Have use throttle body cleaner on them. The coating is still on there as i can see.
Cheers for the heads up tho.
No problem, just giving you the heads up :)
number on front is 49179-53
compressor wheel inlet is 5.5 cm...
looking into it, it seems it will to laggy for drift.
Last question, How many blades on the turbine wheel and measure the exducer on that as well.
P.S. the compressor inducer wouldn't be 52.7mm not 55 would it?
well i think it's an early version (judging by the compressor wheel) of a TD06SH-20G.
It'll be laggy as it's the biggest of the TD06's before you go to a T67. But it's a 330kw turbo.
It's too big for a 20 though, See you should have gone 25. ;)
Edited by D_Stirls
so for track purposes, its not really ideal eh?
im not scared to keep the revs up, and the extra tyre smoke would be kinda cool!
how would i go getting round the coolant lines? join them together?
edit: just seen your edit. i wont bother with it.....
what to get what to get??????????
Edited by craig R33
I'm not sure about that compressor wheel, i can't find anything that even looks close to it and it doesn't look like the current generation of 20G wheels although the inducer specs are very similar to the 20G size.
I have something perfect for you; BRB.
Edited by D_Stirls
Here you go it's a perfect turbo for a 20.
http://www.nissansilvia.com/forums/index.p...howtopic=414681.
You can get 300kw our of this turbo but 260-280kw is more reasonable.
And don't fore get that this is a $1800 turbo when it is new. You might want to change the turbine housing though.
EDIT!! Sorry missed the bit that said that it was sold.....lol
Edited by D_Stirls
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
