  • Replies 14.2k
Anyone who says that semi's are no good on the street really have no idea what there on about. Matt (Whatsisname) has them on his car and he cant believe how good they are either.
I'm thinking it's time for semi's on the street, t1r's are struggling, i'm guessing the ku36's are so cheap because there shit?
Ive looked up the thread on here about the special coating thats on them. Have use throttle body cleaner on them. The coating is still on there as i can see.
Cheers for the heads up tho.
No problem, just giving you the heads up :)
number on front is 49179-53
compressor wheel inlet is 5.5 cm...
looking into it, it seems it will to laggy for drift.
Last question, How many blades on the turbine wheel and measure the exducer on that as well.
P.S. the compressor inducer wouldn't be 52.7mm not 55 would it?
well i think it's an early version (judging by the compressor wheel) of a TD06SH-20G.
It'll be laggy as it's the biggest of the TD06's before you go to a T67. But it's a 330kw turbo.
It's too big for a 20 though, See you should have gone 25. ;)
Edited by D_Stirls
so for track purposes, its not really ideal eh?
im not scared to keep the revs up, and the extra tyre smoke would be kinda cool!
how would i go getting round the coolant lines? join them together?
edit: just seen your edit. i wont bother with it.....
what to get what to get??????????
Edited by craig R33
I'm not sure about that compressor wheel, i can't find anything that even looks close to it and it doesn't look like the current generation of 20G wheels although the inducer specs are very similar to the 20G size.
I have something perfect for you; BRB.
Edited by D_Stirls
Here you go it's a perfect turbo for a 20.
http://www.nissansilvia.com/forums/index.p...howtopic=414681.
You can get 300kw our of this turbo but 260-280kw is more reasonable.
And don't fore get that this is a $1800 turbo when it is new. You might want to change the turbine housing though.
EDIT!! Sorry missed the bit that said that it was sold.....lol
Edited by D_Stirls
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
