  • Replies 14.2k
not you too.....I had an appointment with the hairdresser that I just couldn't cancel
shit pete, your hairdresser must have a pretty awesome car with the amount of times youre there.
As i said in the PM i just sent you i can't be sure about the 3700rpm response as i am only going on the bigger trim versions of the TD06.
Here's the pictures, as you can see it's identical;
FYI the one pictures is for sale for US$300
as long as it starts spooling hard by 3g ill be happy, my 33 with hiflo vg30 spooled at 3200 with full boost at 3800-4000
and that could slide with ease....erm when i took it to lala.
im just gonna take the risk and go for it.
Just letting u guys know there is a huge rbt on south rd near the over pass getting traffic both ways and heaps of cops near cross rd.
i went along south road today
was not fun. 25 kph for over half an hour, and total f**king gridlock on a sat afternoon only ever seen during rush hours on the weekdays. should have gone up portrush road
-D
too many roadworks at one time...
everyday of the week, i come across major works, from the new expressway up north
to the ghey tram overpass on sth rd.
not to mention pt rd in peak hr, that shit can cause hemorrhoids
its friggin stupid
we used to have tramlines extending up oconnell st and into prospect and then they removed them
now theyre building new tracks, using trams that are crappier than those offered back in the day
so, in 40 years are they going to pull these tracks up again? and then rebuild then in 100 years?
Lots of real short term planning going on in this city
Heres a brainstorm - different modes of transport having their own real estate?
it works enough with the Obahn - why cant we have obahns going out every 45' from the CBD ?
Why cant we get bike routes alongside said routes, just like linear park has?
Get the cyclists off the road and onto their own dedicated paths alongside the tram and obahn tracks, emphasize train and tram and bike before busses (because public transport that has to wait for auto traffic is an instant fail), get the trucks off the arterial roads and onto their own bypasses and get rid of this 50kph default speed limit BS.
Thats my rant for the night
-D
ugh. what a morning. bottomed out hard. smashed my intercooler mounts. bent my castor brackets. probably f**ked my exhaust. rails look alright.
probably take it down to a chassis joint on tuesday to make sure everything else is fine, then start replacing the bent bits.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
