  • Replies 14.2k
it was a dip with no warning signs that was behind me before i could even say "what the f**k is that."
had another look just now. castor brackets are bent, castor bushes are leaking, cooler core has been bent and damaged a little bit, bottom edge of the cooler and the pipe work has been pushed back about half an inch, exhaust is now a smaller diameter than it was, front guards need the lip hammered back up again (tyre has gone up into the guards, caught on the lip and pulled it back down), leading edge of the sump has taken a small hit but looks fine from the front (if not, kts high cap sump kit here i come), but the rear end and the rails look fine. the castor brackets absorbed most of the impact at the front end.
but yeah, my fault, even though there were no warnings, if i hadve been paying attention to the road instead of my passenger id be right. shit happens.
:) Yep, pretty much, the great bin incident of '08 :)
lol.
probably. but itd be a lot more effort than its worth.
and they could easily come back with 'you were exceeding the speed limit' (not by much, but i was, plain and simple) and 'if your car wasnt so low, it wouldnt have been a problem', which is true. if i had actual ground clearance i wouldve just scraped my exhaust.
Holy crap! Pretty lucky there Dave i'd say!
Oh and Luke, any tricks when fitting or is it pretty straight foreward?
Guess it will be off with the HKS pods then, just for the extra points with the ladies :)
Guess it will be off with the HKS pods then, just for the extra points with the ladies :(
Piece of piss really, just a tight fit. Handy tip: Fit the AFM's to the box first, then fit the box into the corner, then attach all relevant pipework.
If you need a hand, let me know :)
If you need a hand, let me know :(
where are how much did you get your arc box from?
keen to get rid of my pods for one for awhile now but donno where to look for one.
also looking into a bigger sump and oil cooler after i get back from bali.
Edited by Import S13
Will do man, may inlist your help mate, give you a chance to give it a look over too :(
Sounds good mate, just let me know when and I'll be there.
I got mine from someone selling it on NS, managed to pick it up for $450.
As for the bigger sump, the motor will have to come out, a mod I'd love to do on mine but I've always said if the motor comes out, I'll rebuild at the same time
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
