  • Replies 14.2k
haha, another thing i like about the dirty old sr. dont need to drop the engine to swap the sump. just unbolt the pan, and bolt the new one up.
True. I must say I've been toying with the idea lately of pulling the motor out, doing sump, head gasket, restrictor mod and replacing bearings. I dunno, I'll see how I go :(
Sounds good mate, just let me know when and I'll be there.
I got mine from someone selling it on NS, managed to pick it up for $450.
As for the bigger sump, the motor will have to come out, a mod I'd love to do on mine but I've always said if the motor comes out, I'll rebuild at the same time
thats the easy part. ive got a mechanics workshop at my disposal and we can pull it out and back in ourselves but ive got no idea how to replace the sump
but should be a fun learning process none the less
True. I must say I've been toying with the idea lately of pulling the motor out, doing sump, head gasket, restrictor mod and replacing bearings. I dunno, I'll see how I go :)
Do it man :(
Hey Luke, been meaning to ask, how do you find the ARC air box over say twin pods?
Pods = HAI = Fail
Air Box = CAI = Win
dunno. dont know that area. was on the south side of adelaide.
Dave, it's called Southies Revenge........remember that little Rick Roll incident :(
in all seriousness, I hope you get it sorted bud......you only just got the red beast back on the road :)
as far as the Rick Rolling goes, don't ever try that on the ns site......you'll receive a life ban, just ask Roo....."just quietly" I think it was more to do with his blue mesh! :(
in all seriousness, I hope you get it sorted bud......you only just got the red beast back on the road :(
haha, cheers dude. just running some quick sums, assuming im right and the chassis is still straight (no visible damage to rails, and while it was a hard hit, it wasnt a hard hit) and i replace the exhaust as well, should see change from $1k (sub $500 if i dont replace the exhaust).
but time will tell i spose.
either way, looks like ill be smashing out some overtime the next few months.
Edited by scandyflick
just checked the nengun site james, he has them brand new for 33 and 32 gtr for us$564.76
with the aus dollar not to far behind it might save you some coin if your looking for one?
http://www.nengun.com/arc/super-induction-box
Usually abnormal margins between bonnet and fenders / fenders and doors can tell you if anything is out of whack. Sometimes it just means the car has been crashed before and the job wasn't done well.
all the gaps are the same as they were before. yay.
gonna start pulling shit off when i finish work i reckon.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
