  • Replies 14.2k
haha, another thing i like about the dirty old sr. dont need to drop the engine to swap the sump. just unbolt the pan, and bolt the new one up.
True. I must say I've been toying with the idea lately of pulling the motor out, doing sump, head gasket, restrictor mod and replacing bearings. I dunno, I'll see how I go :(
Sounds good mate, just let me know when and I'll be there.
I got mine from someone selling it on NS, managed to pick it up for $450.
As for the bigger sump, the motor will have to come out, a mod I'd love to do on mine but I've always said if the motor comes out, I'll rebuild at the same time
thats the easy part. ive got a mechanics workshop at my disposal and we can pull it out and back in ourselves but ive got no idea how to replace the sump
but should be a fun learning process none the less
True. I must say I've been toying with the idea lately of pulling the motor out, doing sump, head gasket, restrictor mod and replacing bearings. I dunno, I'll see how I go :)
Do it man :(
Hey Luke, been meaning to ask, how do you find the ARC air box over say twin pods?
Pods = HAI = Fail
Air Box = CAI = Win
dunno. dont know that area. was on the south side of adelaide.
Dave, it's called Southies Revenge........remember that little Rick Roll incident :(
in all seriousness, I hope you get it sorted bud......you only just got the red beast back on the road :)
as far as the Rick Rolling goes, don't ever try that on the ns site......you'll receive a life ban, just ask Roo....."just quietly" I think it was more to do with his blue mesh! :(
in all seriousness, I hope you get it sorted bud......you only just got the red beast back on the road :(
haha, cheers dude. just running some quick sums, assuming im right and the chassis is still straight (no visible damage to rails, and while it was a hard hit, it wasnt a hard hit) and i replace the exhaust as well, should see change from $1k (sub $500 if i dont replace the exhaust).
but time will tell i spose.
either way, looks like ill be smashing out some overtime the next few months.
Edited by scandyflick
just checked the nengun site james, he has them brand new for 33 and 32 gtr for us$564.76
with the aus dollar not to far behind it might save you some coin if your looking for one?
http://www.nengun.com/arc/super-induction-box
Usually abnormal margins between bonnet and fenders / fenders and doors can tell you if anything is out of whack. Sometimes it just means the car has been crashed before and the job wasn't done well.
all the gaps are the same as they were before. yay.
gonna start pulling shit off when i finish work i reckon.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
