  • Replies 14.2k
ahh ok, cheers for that, hope your right haha, rb20de+t would suck.
wonder why it would have ecr32 written on the ecu then?? hmmmm
also, changed my mind on the turbo AGAIN.
did a dummy fit, i would need to run a spacer on the flange coz the compressor housing hits the manifold
before the studs are tightened, and i need an elbow made up.
i do however need a coolant line, the one that goes from the back of the block to the back of the turbs...
anyone got one lyin round?
looms are similar, ecu's are similar
mine's a ceffy x-over pipe on a 32 engine. its a chop and change part, usually means u need the rubber elbow from the AFM with the extra bits if you want to run the factory bov
So are you saying Cefiro RB20's have no BPV/BOV at all? So they come with hektik flutter from the factory?
from what ive found
unless they've popped their donks in j-land and ended up with a 32 engine haha
from what ive found
far out, I guess that blows the "its put there for a reason" theory
Cefiro crossover pipe here:
http://cgi.ebay.com.au/cefiro-rb20det-cros...=item3ef9e4bb5b
yeah look exactly like that.....
if it WAS factory na, it would still have to run na ecu right?
wheres dale when ya need him :P
mr hks, judging by the cars that usually have those stickers i thought that stood for Hyundai Kool Skids
u got the wrong car :P o yeah i said that
ive seen that wing b4
lol all good dude, gives it the track look. n i know how u track racers look down on us mountain passers :)
Edited by Inline 6
u got the wrong car :) o yeah i said that
What you on about?? I dont have any HKS stickers :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
