lol ben. chillax. i dont actually think she has aids (though there is a chance), but i do think shes an ugly scragg.
and thats what I thought u meant but I felt like calling u on it regardless
I know different strokes for diff folks but man she reminds me of the chick that plays Samuel L Jacksons wife in The Negotiator. Whoever she is shes one hot mammasita.... and u know I aint the most handsome bugger in the world, beggers cant be choosers hahah!
youre saying negro american and youre calling me racist? its african american.
youre a lousy person wayne.
and its only racist if i discriminate. which i dont.
Well you're both right and wrong. Negro = spanish for black, so it applies regardless of continent, and is not a derogatory slur, cause as far as the spanish were concerned (cos theyre pale as) the chinese were negros cause they were darker.
i know scandy aint a racist cos he'd root anything on two legs ;D
-D
  • Replies 14.2k
Did I say you mentioned race? No. Others did and I was merely participating in some social commentary...
I also don't understand how seeing ribs means you have aids. You can see my ribs if my shirt is off, does this mean I should book myself in to get tested? :(
Ah f**k it... have fun boys. Night
EDIT: Mitch, good to see someone here knows what I'm talking about :P
:D :D :D :D
them mafkas out day minddddddd
sometimes i love working night shifts. this is one of those times. been able to get a decent bit of work done on the car while the weather is still suitable for humans.
ill spend today chasing up new parts and discussing a new exhaust with andrew, and then hopefully, barring any other things i wanna tinker with, itll be good as new by sunday.
never been to Thailand, but the safest bet is to stay away from any human that even remotely possesses an adams apple.
ahhh thats right, it was carl who was in thailand...
usually the moustaches give it away too haha
-D
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
