  • Replies 14.2k
... like this friend. preferably.
and jake, i see you lurking, if you bring boxxy into this, im gonna cock punch you.
Edited by scandyflick
Silly me, driving to Sturt police station for them to fill out a stat dec. Should have remembered that i have a spool.. and with it chirping away in their very small carpark..can be quite annoying, especially if there is a community watch program finishing up with 3 policeman, and about 10 or so old folk..
Got told to change it before things get more serious with them.
and that was my exciting night.
:banana:
dOEA ANY ONE (fek) know what i can do with teh gas tank in the 31?
its coming out saturday and i dont really wanna have it lying round, specially with this heat we are bout to have.
will scrap yards take it?
<chop chop>
Pfft, you ripped my boxers, thats pretty much the worst you can do.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
