  • Replies 14.2k
Or I can get super discount at Lakeside if you ask me nicely
dear Luke,
Im writing to you NICELY, in hope you may be able to help me with
your trade discount at Lakeside Nissan.
I am in need of:
12x Exhaust manifold stud
1x exhaust/turbo Gasket Kit
4x turbo stud
1x bomb (preferably afghan made) to blow this bitch up.
thank you.
sincerely
Craig Smith.
the new 20 come with a flywheel, which is in better nic than the one i have...
only thing is it has some very light surface rusty lookin stuff on it,
will i need to clean it off? with what??
if i was to sell a car interstate without the guy coming to look at it, how do i transfer rego to him as he wont be able to sign the paperwork?
i'm guessing i need to do it on the rego site or something? i'd just like to have a desposal notice to hand in as soon as it's gone.
Research tells me that i should just leave it and run it, the clutch will rub it off....
i have so much f*king work to do.
just sign your part of the disposal notice and leave it in the glovebox. he will have to transfer the rego from his end.
yeah good idea Damo.
Not only will the buyer get it, but the truck driver, the people that load/unload it, and whoever gets there
greasy little hands on the car....
idea of the century, three gold stars for you.
haha its an SR man, you could put fuel in the engine and oil in the petrol tank and it would still smash the limiter happily.
not quite. sr's have a bit of a love/hate thing with rev limiters.
its the rb20's that you can do that do and still live on limiter without harming it.
lol, i want the disposal notice.
so incase he never changes the rego to his name in the other state it cant be linked back to me for any stupid shit that he might get cought for.
there would have to be away to do it online but im wanting the notice with his signiture onit.
hoping someone on here might have done it.
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
