  • Replies 14.2k
I wrote this up for when i sell my s13 but since I've been asked about it a few times already without putting it up for sale heres the specs
YEAR 1989
MAKE Nissan
MODEL S13 silvia - resprayed custom green – manual
MODS
Ca18det
engine has received a full o/haul and metal head gasket
kkr 330 turbo fully rebuilt with garret gt28rs internals
supra front mount with custom piping and custom intake pipe
speed lab remap
gtr fuel pump
poly urethane engine, gearbox, and sub frame mounts
gtr rear sway bar
cusco camber and toe arms
moon face traction rods
poly urethane castor rod bushes
ram rear coilovers, gab front coilovers
lock spacers
brand new exedy clutch (seen 3 track days)
new clutch master and slave cylinder and lines
full turbo back exhaust
drift handbrake button
cusco mech 2 way lsd (also seen minimal track time since new)
skyline rear 5 bolt drive shafts
obx bucket seat
clarion head unit 45x4 and clarion 6x9 speakers
16x7-0 and 16x8 +2 ssr xr4 longchamps
Pink steering wheel (straight from japland :P)
Front lower lip
Front and rear strut braces
52mm alloy radiator with all new JJ silicone piping
EXTRA COMMENTS car is fairly straight with the body work could use a little tlc, chassis is immaculate with no rust or dents in the floor pan, it made 176rwkw with the retune and has more in it if the injectors and AFM where upgraded, basically a tough street car with plenty in it for drifting.
This car has seen track time but not much at all. 3 times since January is it and it doesn’t get driven unless its going to the track. I do start it and roll around the winery where its kept in a shed at least ones a week to keep it healthy.
nearly tempted to throw in my build for that lol
cant really afford it tho :P
in parts is prob worth 8k with the rebuild otherwise id sell cheaper but just to much put init.
been told its the best sounding ca heaps of times too, pops decent flames and proved itself on the track.
have think about it dude, could be cheaper in the long run insted of building a car from scratch and this ones got some decnt stuff onit to get you started :P
heres some pics to get you thinking. its before the paint job though.
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
