Shouldn't need replacing. They're brand new ISC N1s. Well according to Ryan hand tightening the bolts isn't enough and a rattle gun needs to be used.
ahh well i doubt theres a problem with the shockers then, its probably like matty said, maybe your new kick bottom suspension has hastened the demise of the old joints... but then again
<--- not a mechanic
maybe make a set of handlebars and a foot rest so u can use ur new n1's as adjustable pogo sticks...
-D
  • Replies 14.2k
You tell me Chad.
Pillow ball like the ones in my Stagea. I wish mine were rubber tops like my skyline, its so much smoother on the road.
My stagea has no front bump stops and it was so low that when i hit a bump it would bottom out the shocks, maybe that could be your problem?
Edited by DSTROY
I got a leaking bush in the right.. But not in the left. Also I don't see what a rattle gun is going to do compared to hand tightening the f**k outta it. Hmmm. I'm going to have to go down to Pedders tomorrow and see what they think.
But I don't think that I'm hitting anything because its too low (because it only started doing it this morning). There is endless possibilities. But I'm leaning away from the coilover being faulty.
I hope
Sorry Matty didn't see your post. You reckon its ball joints? Should I get them done like.. ASAP or would I be able to drive till I got the spare cash to fix em?
s'alright mate. first thing ive learnt to check from every 31 with coils ive been in thats clunked. always seems to be the ball joints that are f**ked (or in your case a bush thats f**ked)
get them replaced with some genuine ones and you'll be sweet as. amazing how much stress and strain coils put on the rest of the suspension components
hmmm, forgot to factor that into my build...........new bushes all through the car. crap. there goes more cash :P
South Australia delivers again!!
Hell yeah, good idea, lets rebuild Adelaide oval even tho we have AAMI stadium.
lets do it to make sadelaide look appealing to our interstate neighbors!!
why waste the f*kin money? srsly.
all this and its to much to ask, for a simple 1/4 mile peice of flat fkn bitumen.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
