  • Replies 14.2k
While I'm here ...
Can anyone tell me, or point me to a link, as to how a GTR/260 gearbox pull-type clutch fork mates up with the pull-type clutch kit, so the clutch engages properly. Push type I know you just slide things on. But is there a trick to fitting the GTR box to a pull type pressure plate and carrier?
Thanks >_<
while i was picking up my car i asked this qeustion today as my intention was to drop by and help.... unfortunataly i didn't sleep last night and afterwashing my car i had a quick cat nap that i only just woke up from =\
i know there a BARSTARD to get off (right matty/blue 32) =P
but apparently you can assemblem the forks and everything and then set up the thrust bearing and just "click" them into place! soooo much easier than removing them!
That's 'cos I killed the pigeon with my gas when I was changing your turbo
normally id be inclined to agree, but i didnt put the hks piping on until just before the private day.
Chuck up some specs :)
Its a 88 model was auto by the looks of it, RB20 it pretty much stock engine wise. Its supposed to has a Autech ball bearing turbo, Nismo suspension and a fairly new Exedy clutch which a cant seam to take off without chirping the rears :D It def needs moar powers as it has trouble spining the wheels in second. Rims are 15's with 205's so i'll keep them for sliding as they are easy to replace and i'll see if my drifteks fit on the front.
What should RB20's rev too? 7000?
Most definitely.
1998 Black R33 GTR series 3.
~100k km,
400R Front Bar,
HKS 2530 turbos,
18" Nismo LMGT4 wheels,
Loud. Fast. Unbelievable!
PM me if you want to know more.
dang it, i so didn't want anything to do with this thread grrrr
be more aggresive with the clutch, 20's got enough power to slide a ceffy lol
Pretty sure its just running standard boost, its not very fast atm. It may still have an auto diff as well which wouldn't help.
Sounds like awesome fun man.
I'd be inclined to rev a Rb20 to like 7,500?
God hearing about you having a track cars really gives me the itch to hurry up and convert my S13 to manual.
hmmm
Im off for a spin in the hills
wish I could sort out my ecu and get back to 7200rpm limiter
currently cuts at 6500, some sort of issue with the AEM F/IC-8 ecu I have, as the remaped stock ecu is set to 7200
meh, changes gear right in the meat of the power delivery so it isnt too bad.
surprising tho that a little 700rpm means my car is down ~15rwkw
ie 6500rpm = 240kw, 7200rpm = 250kw+ going by the dyno graph(s)
RB20's semi redline at 7000 and full redline 7500.
My limiter was ~8000rpm.
Went for a spin in my managers R33 S2 tonight lol, it did give me a Skyline fix thats for sure.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
