  • Replies 14.2k
Well, I got out sticker free, can't say the same for Dave or my mate Bengi though (HELSLO)
I went back after I got home, in my missus' Pulsar. Seems like the cops ripped most people a new one. Saw a fleet of about 6 cars leaving; all with stickers. Then one on a flat bed.
Being in the first group, I did see my fair share of stupid driving, many many link ups around corners, etc. Not stupid speed just stupid driving. I just feel sorry for those who got done as I know a lot of them weren't the ones driving like that
was it a resident that was filming at corkscrew? I went past and there were subarus that were on the cruise on the side of the road - thought it was one of them stopped to film?
it'd be nice if some of the dickheads that were being dori heroes actually got cained from video evidence
this is one of the reason that whenever I do a cruise, its with 4-5 other cars and all of them are by invite only
sad that a charity cruise is misrepresented to the public and police because some small dicked idiot couldnt keep it to lala
-D
-D
Could not have put it better myself Ben ;)
There was about 4 younger dudes film9ing, egging people on..and it worked. Also, has a bunch of kids about 10 or 11 doing the wheelspin thing with their hands going through one small town..laugh of the day that was
Yeh the subarus were at the start of the corkscrew on side of road filming then further up was an old guy filming. He was prob a resident, maybe he'll give the footage to TV stations. Lol about, if ur lost follow the skid marks .
so Dave copped a new sticker?
was it maybe karma biting you in the ass for what ya did leaving my driveway this arvo? ;)
sucks to hear tho mate, from whats on the ns.com thread, sounded like a decent drive.
be good to know the $$ raised
can we get a copy ;) or do we have to watch for today tonight release
By SAPOL or by the Olds?
Call of the week,
I enjoyed today. We got caught up with all the track cars some how so we pulled over and decided to let all them skid heads passed and then yeah.
I enjoyed the roads, they're fantastic and the track cars no doubt put on a good show but it is a massive shame to see stickers handed out at a charity event. We got a call saying dont come theres cops everywhere so we just went to a pizza bar and got dinner then home. We donated a whole bag of toys n what not
When you see cars drifting onto the wrong side of the road around corners they are the guys you should be blaming not sapol. At one stage a car coming the other way had to stop because their were cars coming head on with them in their lane doing burnouts so big that i couldn't see anything but white smoke. They are the knobs to blame!
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
