Aussie's will most likely loose this test match and damn right they should....a poor first innings performance by them see Pakistan in a easy position to take a win...currently 3/65 and only needing 176, which i think that they will comfortable get....
will make an exciting third test :D
:) we win!
  • Replies 14.2k
Indeed! Great bowling and Ricky's a great Captain no matter what the knockers say :)
Your right. i cant believe people say ponting's a shit captain. The same people say Johnson is a crap bowler.
ffs. Ponting was announced the highest winning captain in cricket history.
Johnson has the most wickets around the world with the best bowling avg. :D
johnson IS a crap bowler- being a lefty tho he ends up getting the angle across for plenty of edges from RH batsmen
strays far too short and wide far too often.
needs to watch bruce reid at his finest to see how a proper left arm opening bowler does the job.
ponting is a decent captain no doubt, however if warnie was made captain at the time he'd a) still be playing, and b) aussies wouldnt lose many matches.
best cricketing brain (warne) for a couple of decades IMHO
theory on angle ;
whats the diff between a right handed bowler bowling to a left handed batsman ? there are plenty of left handed batters too.
He does stray a little sometimes. But his figures speak for themselves.
Most wickets and best avg this calendar year. How can you say hes crap ?
Id be more 'scared' facing reid (back in the day) than johnson.
Johnson leaks runs, plus you know you'll get a straight short one (guaranteed) for a hook/pull and a wide one begging to be cut for 4
if we are talking variation than Tait would be the best bowler out (yeh fat chance) simply 'cause he cant string two good balls together
fact is, left handed batsmen face a hell of a lot more deliveries from right handed bowlers, over rh batsmen facing lh bowlers - there arnt all that many left-handed bowers out there.
practice makes perfect.....
RB20's are tough little luggers, mine has between 80 and 92PSI on ALL 6, and it has oil in the water, but it still pulled quite a decent figure a couple of weeks ago..
and it blows smoke too..
LOL my old 20 was the same aye. Blown head gasket, blown water pump and a big arse crack in the exh mani right at the collector and it was still cranking skids right till the end :D
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
