  • Replies 14.2k
So we have the green light from the association to play cricket tomorrow, in confirmed 41 degree heat. we dont get cancelled til 42, which i think is f**king stupid. Last season it was 39, who the f**k thought it was ok to play in 40-41 degrees?
/serious cat.
have fun in the heat Damo....while your doing that i will be lounging around in the pool with a few cc and dry
Epic!
I'm spending tomorrow decorating the shit out of a hotel room I rented for this chicks birthday. I've hired a helium gas cylinder and shit for the balloons... gonna look crazy haha.
off to whyalla tomorow for my first ever drag meet with the 31 cant wait :rant::rant:
Im heading down there tonight to see my old man when is this drag meet on cause i wouldn't mind watching and maybe taking the GTR down the 1/8 mile
Wouldn't Whyalla be hotter than Adelaide? I wouldn't be pushing my car in this heat. But thats just me :rant:
Its wishful thinking im already dreading the drive there cause i dont have aircon... besides i dont really want to risk taking it down the strip anyway in case i break it cause then i gotta get it back home again by monday.
mt gambier is a bit cooler and still its farking hot outside....would hate to think what its like in adelaide thank god my flight is a late one and gets into adelaide around 9.30ish things should cool down by then hopefully lol
It's stupidly hot outside at the moment... I'd hate to see temps up north!
yeah always 2 degrees hotter at elizabeth.
Krishy, next 3 days will be 40's, so i doubt it will be much cooler here at night than gambier in the day, haha
I see what you did there :rant:
I actually didn't realise I put in a double meaning there :rant: But now that you pointed it out ... I wouldn't be physically pushing any car either :rant:
Quite a few cars on the side of the road today! 52mm alloy rad, FMIC and re-gassed air con FTW!!!
who knows their steering wheels?
any reason why the detach hub kit ive got would have the correct bolt pattern on my boss kit side of things, but i go to attach the nardi on the detachable bit and the hole pattern is narrower than the nardi one?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
