  • Replies 14.2k
Depends what you want i guess, Internally gated or External.
GT3071R Dual BB rated at 500hp, $1,815
GT3071R T25/T28 Internally gated with a .64 rear housing, $1,795
GT3071R T25/T28 internally gated with a .86 rear housing is also the same price as the one above.
Courtesy of Tweakit.com.au
its pretty expensive build to do tho.. some1 told me on ns.com to have 20g ready to do the 3071R turbz on my pulsar(plus the supporting engine/diff upgrade) he also told me my straight cut gears wouldnt be able to handle 300awkillerwasps, is there many things stronger than ppg straight cut gears?... bit of a turn off right there...
Jeremy i reckon he doesn't know what he's talking about 20k is rather large and gtir are already turbo
only thing is 3071r on a 2.0lt might be a bit laggy
ring AM Performance he makes dumps and might know a lot more about the gtir that some rando on NS
oh and i know 3071r isnt rated for 300kw i just asked about that seperately.. if it was 15k id do the pulsar, 20k is pushing it... got to get rid of the stupid s13 :)
How much for the sil?
lol that turbo will do all of that.....should be quite responsive with a small 0.64 rear housing.....mine is a 0.62 or a 0.63 rear housing and see full boost by 3200-3400rpm.....
http://www.lovecricket.com.au/
so far my highest score is 105
