  • Replies 14.2k
awesome
Ive got the $5 ebay bhp-steel roll cage, and mate is welding it in
stipping atm, half stuff sold.
got another 1g to get back in, once the seats/interior skins sell, etc
then need ku36 tyres,
track qfm pads,
powerfc (from fishpaste),
and injectors & tune
then ready for mallala :)
cheers mate!
yeh the zx9r is sold for 5600, awaiting deposit, didnt lose any $ on it - only rode 300kms in 8months :(
just the knees - cant do it.
so hence the r32 purchase; currently costing me exact same as the bike sale !
ie a swap over.
get it down to around 4500 in cost from 67000 purchase price,
then add in the bits I need
should be a $7k track car, TT at that!
~250rwkw at 1bar Id suggest
oh yeh, just won ebay a garrett 18psi actuator.
off goes the hks 14psi unit, on goes the manifold Ive treated and the actuator.
:):D
sled - no more bike. sorry before, months ago, but I took offence to something you said
re: bike, pension, ..... i made a complaint to andrew about it.
anyways, I reckon you're doing a bang-up job for sau:sa... keep at it. :)
only managed 300kms in total of rides on the bike, just couldnt do it without patella's
so yeh sorry for arching up months ago, you're a good mod for sau:sa so yeh kudos 2u :)
What you doing with the 14psi unit? :)
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
