  • Replies 14.2k
Lingerie football team would be the Magpies saving grace!
nah, it'd distract the port supporters from stealing car radios to hock at cashies
without that, they wouldnt be able to get into the game with a 6 pack of vb
-D
DEAR SIR,
you seem to not want to live/want your f40. please leave me the keys and go jump off a cliff for A. leaving 1 of the most respected supercars parked in a friggen street car park and B. attaching roof racks like it was designed to do your daily chours of lugging around your stupid bike.
Edited by Inline 6
No offence Mitch, but it seems you're a little stubborn. I don't know your exact situation but it seems you have no job, no source of income yet you seem to be constantly tinkering with your car which costs $$ and ends up costing you more $$$ with problems like a defect. My advice to you, and please don't take it the wrong way is to sell the car, get yourself back on your feet then look at buying another car. It's not worth running yourself into the ground over, cars can always be replaced mate, your sanity and financial well being on the otherhand can be a little more difficult. It's a simple case of trimming the fat. We all know these cars are expensive, do the math, I think you'll come to the same conclusion too.
Just me friendly advice, take it for what it's worth
what's the 2nd one for Mitch....judging by your comment, I'm guessing it aint gonna be an easy one to get off?
suspension 2" too low and its gonna take a shit load of work to clear regency
No offence Mitch, but it seems you're a little stubborn. I don't know your exact situation but it seems you have no job, no source of income yet you seem to be constantly tinkering with your car which costs $ and ends up costing you more $$ with problems like a defect. My advice to you, and please don't take it the wrong way is to sell the car, get yourself back on your feet then look at buying another car. It's not worth running yourself into the ground over, cars can always be replaced mate, your sanity and financial well being on the otherhand can be a little more difficult. It's a simple case of trimming the fat. We all know these cars are expensive, do the math, I think you'll come to the same conclusion too.
cheers Luke,
thats exactly what im thinking right now , just have to see what happens over the next couple days and act on it then :stupid:
ASAP would be good, but if you cant...you cant. Just as long as it is done BEFORE 1st March - as i have to give Dion his car back before then.
i'll be able to do it either the friday after i get back or the saturday (either way)
still ok to tow my car matty???
yeah yeah, still alright to tow u mate. i dont go till monday :stupid:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
