  • Replies 14.2k
moar info pls.
does it dip in revs after u back off, idle rough when cold etc ?
Bit hard to explain. It doesn't really change in revs, it just seems to "shake" a bit more at times when it's idling in neutral. No difference id the engine's hot or cold.
I'm going to have it checked out sometime, but I was hoping to get some sort of a diagnosis beforehand.
Then again I've been told that 34s tend to sometimes idle a bit rough by default. Probably also a case of an aging car.
thought id express my inner anger..
shittest situation...
car is unregistered and on double defected
its going to cost $50~ to get a permit , then ive gotta go to a cop shop and get a clearance note , then come up with $200~ for rego , and another god knows how much for regency.
not to mention stock parts.
all unemployed and without a car...
and looking after a parent.
so angry :)
/end rant
just bought a ''new'' car
ended up gettin a 99 VT II calais supercharged 6, pick it up tomorrow night :)
muuuuuuch better than the Vectra, why i ever thought that was a decent car, i do not know!!
meh, not really interested in modding it, the missus and boy will be the primary passengers, as it
sits will be fine, the only thing ill be doing is 30% tint...
in other news, pretty sure i get the 31 back this week aswell! awesomeness.
so angry :)
/end rant
I didnt think you could rego a defect vehicle? Whether you have a clearance or not?
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
