  • Replies 14.2k
hey dion are you hiding from me and james lol
I see you lurking Mr Crossman :P
I told you guys, today is my study day, have to limit contact with the outside world :cool:
Looks like you have a bit of sunburn in those pictures James.
lol, and I spilt drink on myself before those photos haha
Spent the day putting up my new fence, and fabricating a sliding gate (to be automated) at the front of the house. House extension is on hold at the moment whilst I've got re-submitted plans with Council, waiting on approval for some engineering changes (floor framing). Gotta keep moving on with the house, so the front yard is getting some security upgrades ... 600mm high brick fence is now 1800mm high thanks to timber slats. Gate is under construction. And I'm ripping up the front lawn for an extra driveway addition.
Next weekend, I finish the gate, and render the front of the house. Busy much? :cool:
Well I've probably found my house. Walked in today at the open and just had a gut feeling this was the one. Not getting too excited yet just incase I don't get it but will be making an offer on it :cool:
good job luke, if it is anything like your gut feeling with the CTR then it it must be the one...
Fingers crossed... was actually coming back from seeing it when I spotted you! Just off Hillendale
fingers crossed...or fingers up ya jerk? at least its not far from where you are now, did it have a small garden shed out the back? if so its definately the one :cool:
Massive shed! Lots of parking space, reno'ed kitchen, bathroom, etc. Price seems right. I like it!
excellent, as long as there is enough room for a single bed, the GTR and a little mazda, then you are pretty much set.
and i beleive we should use this as our new mainstream form of communication, it is so much easier to get into contact with you lol
:cool:
Yeah, it's pretty nice, got a few ideas in mind already if I do get it, just don't want to get too far ahead of myself
And wtf that car is hideous
Here ya go. Pics really don't do it justice though
Looks nice, good luck. I made heaps of offers on houses when i was looking and all offers were above the asking price and i still missed out on about 6 or so houses, was a crazy time to buy.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
