I fitted an ISC kit to one of my mates R33 and it was a pain in the ass. None of the bracket fitted and the drivers side piping was no where near close to fitting. the passangers side was close to fitting but did need to be modded.
In the end i made up my own brackets, cut the pipes and bought two extra silicone fittings it it fit then. I think it was sold as an R32/33 kit and it definatley didn't fit an r33.
  • Replies 14.2k
When i rang Ryan to find out what was going on he pulled out the old line, "i've sold heaps of these and i have never had anyone have a problem with fitting them". i even sent him pictures but never got a reply.
If the brackets had fit then the piping would have fit, but the R33 have a thermo fan infront of the air-con' heat exchanger which ment that the bracket were to short. I then had to cut the shroud around that fan and make up longer brackets that sat the inter-cooler further forward which then ment that the piping was too short.
The drivers side piping was also on the wrong angle where it went through the guard below the washer bottle.
With my 180 i made up my own piping which although it took a bit longer and was more expensive (it was $505 for everything as opposed to $300 + the extras which i think was $150 for the ISC kit) it fit better and being stainless it looks better and will always be the way i will go with my own cars. Although i might try and make my next piping up out of aluminium.
Edited by D_Stirls
Why didn't you buy the same then silly boy? aha
not my car mate! :P
Yeah mine came from Just Jap too, but front bar modification was the biggest pain in the ass.
i dont mind the front bar and reo mods, but trimming fans and modifying brackets shouldn't be necessary!!! being a mass produced product and/or rip off of a Japanese kit, you'd think they'd make these things right and to fit without too much stuffing around!
every part of my body wants to really make my wheels fit, but at this point in time its looking 100% un-acheivable without making the car a TOTAL cop to drive. by this I mean, heaps and heaps of camber, stiff as fark coilovers etc
I use the GT-R daily, I am by no means looking for a silk smooth ride, after all its a GT-R but with stupid amounts of camber the road chews thru tires... ehhhh. When i bought these wheels I didn't think it would be this hard lol.... :P
Yeah oath, my driveway is on like a 30degree incline probably more.
I've got 245's on a 10" wheel, jacked up 3.5cm just to get in and out of my driveway... what more what you like faaark lol.
bro its not just the guards that are the problem I think.
I think because my coilover spring rates are mallala spec they're on 5krear 6k front it allows the coilover to travel a bit more as the weight transfers going over things and up my driveway to then force the wheel to touch the guard while reversing out on an angle.
My stagea is a daily with 19x8 +30 on the front with 30mm bolt on spacers = 19x8 0 offset with none stretched tyres, rubs like crazy on big bumps and in the hills etc etc, really not that big a deal, rather have my car look like WIN and scrape than look like fail and aids and not scrape. Luke had 18x10s on his 4 door. If you want your car to look average then sell the rims but if you want it to be a stand out/look tuff as all fuc then make them fit.
My 2 cents.
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
