Signed the paper work for our home and land package this arvo
ended up going for this http://www.sterlinghomes.com.au/home-desig...cquarieensuite/
house and land package at munno para west, along with a few extras like stainless appliences, built in robes etc etc
come to 232k
will do me the missus and the little lad for a few years, then rent it out and onto bigger and better :D
just gotta flog this unit off now!, word of advice, avoid northern property world, there useless pricks.
good price and a good looking area!
  • Replies 14.2k
kellie
ring 13 13 66 straight away. thats a broken neutral (as brad and i both thought earlier)
describe it as you got a shock from a tap when trying to turn it off, and a customer service crew will be sent out.
do NOT ring an electrician yet, ring ETSA straight away
^^^yes agree and thats why you would get a shock because it is using the earth instead of the neutral of the house as the return path
Thankyou guys i told my landlord what you both said when he called back and he agreed.
so i called ETSA they came out and the big wire that goes from the stoby to the house was fried, he opened the box on the roof and said he needed to turn off the whole house straight away because the earth was burnt off and he put his tester thingy on and he said there is 180,000 volts and this is dangerous, so it was feeding that elctectricity to the whole house hence why the taps were alive and i got shocked.
After a few more hours my arm was still hurting and the ETSA man told me i need to go straight to hospital due to the fact that when most people get a shock like me they think they feel alright but you can die hours later due to your heart. He worked out by how many things were on in the house and and told me that aprox 63 volts shocked me.
So i went to the hospital had to have all these heart things on and had to be monitored for several hours, the Dr came and saw me and told me im very lucky my ECG was ok and there doesnt seem to be any signs of damage just some mussle spazams but ill be ok
come to 232k
all i need another hoon in the area lol it's bad enough with the multi coloured cordia with the blow off valve that sounds like a runny fart lol . congrats on ya house what pt of munno para west you buying ? i hope it's not in lego land lol
now i dont want to touch things in my house :D
filthy dirty.
seriously. f**kin things filthier than a 17 year old girl at schoolies. ill give it a wash and take some proper photos whenever i can con luke into driving it. :D
come to 232k
Nice mate, there's a few of us here that live around munno para area...Where bouts you building it??
Yer so many commodore drivers around here Deano, seems its getting worse as well!! Haven't heard the cordia yet, keep hearing sr's getting driven hard...Meh! Lego land?? Would that be the area on the corner of ponderosa road?
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
