Signed the paper work for our home and land package this arvo
ended up going for this http://www.sterlinghomes.com.au/home-desig...cquarieensuite/
house and land package at munno para west, along with a few extras like stainless appliences, built in robes etc etc
come to 232k
will do me the missus and the little lad for a few years, then rent it out and onto bigger and better :D
just gotta flog this unit off now!, word of advice, avoid northern property world, there useless pricks.
good price and a good looking area!
  • Replies 14.2k
kellie
ring 13 13 66 straight away. thats a broken neutral (as brad and i both thought earlier)
describe it as you got a shock from a tap when trying to turn it off, and a customer service crew will be sent out.
do NOT ring an electrician yet, ring ETSA straight away
^^^yes agree and thats why you would get a shock because it is using the earth instead of the neutral of the house as the return path
Thankyou guys i told my landlord what you both said when he called back and he agreed.
so i called ETSA they came out and the big wire that goes from the stoby to the house was fried, he opened the box on the roof and said he needed to turn off the whole house straight away because the earth was burnt off and he put his tester thingy on and he said there is 180,000 volts and this is dangerous, so it was feeding that elctectricity to the whole house hence why the taps were alive and i got shocked.
After a few more hours my arm was still hurting and the ETSA man told me i need to go straight to hospital due to the fact that when most people get a shock like me they think they feel alright but you can die hours later due to your heart. He worked out by how many things were on in the house and and told me that aprox 63 volts shocked me.
So i went to the hospital had to have all these heart things on and had to be monitored for several hours, the Dr came and saw me and told me im very lucky my ECG was ok and there doesnt seem to be any signs of damage just some mussle spazams but ill be ok
come to 232k
all i need another hoon in the area lol it's bad enough with the multi coloured cordia with the blow off valve that sounds like a runny fart lol . congrats on ya house what pt of munno para west you buying ? i hope it's not in lego land lol
now i dont want to touch things in my house :D
filthy dirty.
seriously. f**kin things filthier than a 17 year old girl at schoolies. ill give it a wash and take some proper photos whenever i can con luke into driving it. :D
come to 232k
Nice mate, there's a few of us here that live around munno para area...Where bouts you building it??
Yer so many commodore drivers around here Deano, seems its getting worse as well!! Haven't heard the cordia yet, keep hearing sr's getting driven hard...Meh! Lego land?? Would that be the area on the corner of ponderosa road?
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
