  • Replies 14.2k
does any one have a tent i can borrow for this weekend it will be for me and locky
Kellie, I have a spare tent for my bike trips. I think its only like a 2-3 man tent. I usually keep it as my back-up on camps when not in use on motorbike road trips, so I'll have it with me at Collingrove.
quick Q, I'm sure a few of you lads should know:
Can I buy a cams L2 non speed licence (for drift pracs) without being a member of a club?
Might finally stop buying and selling cars and stick with 1 and make a good slider out of it one day soon :D
On that note, anyone want an RX7? :)
Might finally stop buying and selling cars and stick with 1 and make a good slider out of it one day soon :)
just join SAUSA you tightass :D
just join SAUSA you tightass :)
But I'll probably end up with a beater S13, prob won't be welcome lol
no you need to be a memeber of a club that is CAMS affiliated
also you dont need one for drift prac because a one day pass is included with the fee but to do a G1 drift event you need to buy the L2NS
Cheers for the info :)
I'd probably prefer to get a year licence so I don't have to bother with the day permits but I guess I could rock it like that for a bit. I probably could've bought a few years worth of licence for the amount of day permits I've got over the years drifting though :D
Never! being a forum member of SAU is enough to show your an enthusiast of the Nissan Skyline, so you would be more than welcome!
errrmm.... no.
its $10 entry at the gate
$90 to slide
+ 25 for a day license if no year license
if you have a year license its 100 all up.
Edited by craig R33
errrmm.... no.
$90 to slide
yeah but to get a full license, you need to be a member of an affiliated club
Matty T who's doing your cage?
Lance quoted me 2200 for a full weld in then a couple of hundred extra to have the cage go through the fire wall to the strut towers which im defiantly doing, so around 2500 for a full weld in, which i thought was cheap :D
Earliest they can do it is July :).
Craig Helps is doing mine, same deal with the basic full weld in, plus im getting a heap of other bar work done (sill bars, few extra cross bars etc). mine will probably be going in during may while im in whyalla
Paint them yourself Matty, I did my 31 covers 8 years ago with bright red VHT paint and they still look show room fresh.
and if your keen on some airbrushing flames or ? then pm me I might be able to hook you up
just make sure the rocker cover is spotless outside and a light scuff with a scotchbright, the logo if its has one can be removed and polished up or ?
ive got redtop RB20 covers troy, something like this:
want to paint them up as bright as that (with the valley cover and cam gear cover in black)
i dont feel confident doing them myself, happy to chuck you some cash to do it though :)
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
