  • Replies 14.2k
noticed the other day that my rb25det has a little oil in the coolant, not enough to change the color of the coolant but i can notice it when its in a puddle on the ground.
It seems to have lost abit of power from when i bought ( 2weeks ago), it does have a coolant leak from the block ( not was whats the parts called but ordered a replace from nissan, 3 weeks away, also ordered a coolant temp sensor as it wont start first time without pumping the accelerator.
Car doesnt show no signs of over heating, just a slight bit of oil in coolant and loss of power?
I wouldn't drive it if I were you.
This problem gets worse, not better and it's only a matter of time before the reverse (much worse) happens, if it hasn't already, ie. water in oil.
Sounds like a track between water jacket and oil gallery.
huh
if coolant is leaking from the gasket out your head running down the side of you block how is oil going to find its way into you radiator
yeah after re-reading it a few time i finally saw my errors :merli: brain was faster than my typing
haha, cause coolant already lives in the radiator bud.
I think you meant oil in the radiator which can track between galleries, cylinders and externally.....depending on whether it's a head gasket issue, cracked head, warped head, corroded head, etc.
i had a similar failure in my mx83 cressida. had a wee bit of oil in the coolant, then eventually the metal ring in the gasket around piston 6 distorted letting water in to the combustion chamber.
needless to say piston 6 was looking nice and clean after its steam bath :/
replacing head gasket isnt that hard, if you are doing it yourself make sure you take pictures of everything you take off so you have reference to put it back together :/
    • My 3.8 kW system (when new, not so much nearly 20 yrs later) will do 21 kWh per day (best few months of the year), and that's with an afternoon shading issue. So it really could/should be able to do maybe 24. So a 6.6 kW system probably cannot fill a 40ish kWh battery from scratch, but then it is very unlikely to ever need to. Let's presume that you use 10-15 kWh during the day and stash the rest. So long as the battery isn't drawn down below ~50%, it'll be fine. And that draw down presumes using 20 kWh overnight, which is a reasonably heavy draw. So that seems reasonable. The 40kWh will be good for extended outages, and very bad days where you get almost no generation for a day or two. Might struggle to top it all the way back up after it gets pulled all the way down though. I'd think you'd probably want about 10 kW of panels to make life a little easier, wrt keeping a 40 kWh battery charged. But then....does it really need to be at 100% every day? Probably not.
    • Am I wrong in thinking that there is a hell of a lot of battery storage for a 6.6 feed into it Your battery is around 4 times bigger than the battery that is going into my place in a week, but I have nearly twice the feed Will the batteries actually ever get fully charged? School me on the science bitches
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
