  • Replies 14.2k
noticed the other day that my rb25det has a little oil in the coolant, not enough to change the color of the coolant but i can notice it when its in a puddle on the ground.
It seems to have lost abit of power from when i bought ( 2weeks ago), it does have a coolant leak from the block ( not was whats the parts called but ordered a replace from nissan, 3 weeks away, also ordered a coolant temp sensor as it wont start first time without pumping the accelerator.
Car doesnt show no signs of over heating, just a slight bit of oil in coolant and loss of power?
I wouldn't drive it if I were you.
This problem gets worse, not better and it's only a matter of time before the reverse (much worse) happens, if it hasn't already, ie. water in oil.
Sounds like a track between water jacket and oil gallery.
huh
if coolant is leaking from the gasket out your head running down the side of you block how is oil going to find its way into you radiator
yeah after re-reading it a few time i finally saw my errors :merli: brain was faster than my typing
haha, cause coolant already lives in the radiator bud.
I think you meant oil in the radiator which can track between galleries, cylinders and externally.....depending on whether it's a head gasket issue, cracked head, warped head, corroded head, etc.
i had a similar failure in my mx83 cressida. had a wee bit of oil in the coolant, then eventually the metal ring in the gasket around piston 6 distorted letting water in to the combustion chamber.
needless to say piston 6 was looking nice and clean after its steam bath :/
replacing head gasket isnt that hard, if you are doing it yourself make sure you take pictures of everything you take off so you have reference to put it back together :/
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
