  • Replies 14.2k
yeah unfortunately I have to look at it this way as well.
I wanna take the fam to Europe & the States before I do Japan
Same here. I'd love, love, love to return to Japan (lived there for a stint in 1997), but I really want to go to the IOMTT in the UK. And Tracy would love to visit London again.
:D
oh Dan, i agree. This dumbass on facebook that went to my primary school, my god. Constant updates like this:
"do u think thr is one person ur sapost to b with 4 the rest of ur life"
"who r my close frnds"
"bye all gunas watch dvd"
"all u fkers that ses sht to my fam get a life im not hvn a baby got it"
Sad thing is, its only gonna get worse - teachers don't teach grammar the way they used to it seems, and when newspapers employ journalism students who cant use a dictionary or thesaurus, then you know the people reading it are going to pick up the same bad habits.
Check out any article on adelaidenow.com.au for example.... loads of error, and it seems that the editor doesn't edit anymore...
Mind you this was inevitable since we lost the news years ago - having a single newspaper in a city doesn't do anyone any favours.. and for what its worth, the australian seems to have more important articles, rather than be filled with nonsense about what b grade celebrity is doing what. They even dedicated a whole page to Kellie Nestors impending pregnancy - which is nice for the girl but cmon, is that newsworthy?
-D
EDIT - Not in a GTR nigel, but did get a very nice one made up for my old r31 by boss engineering at lonsdale - top work if you're interested in getting a replacement
Nigel what u wanna know? I got a bnr34 nismo 1.5 LSD on it's way for me atm. Will also be going a nismo 1.5 for the front. Some people are also using the quaife front diff but they are around 2k where the nismo front is 1300ish.
I have a collapsed bearing on the drivers side, and its been slipping a fair bit lately. So thinking of upgrading to a aftermarket, because im sick of replacing diffs and drivetrain components on this car and want something stronger!
KAAZ dont make a 1.5 way, where Nismo do, and i think OS Giken do too.
Don't want to spend more than I have to, as I've just been informed that my transfer case requires work now too GRRR
394 defect notices since july last year.....umm i wonder how many of them were "pod filter not secured" kinda defect.....they dont defect the rust buckets out there either.....some nice revenue raising for the govt
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
