I did man, can't use my phone atm though - I'll let you know once I knock off.
On a side note guys, can you have an open face helmet on the track at mallala? As long as its aust standards of course
Edited by Weezy
  • Replies 14.2k
yeah, i dunno man.....
doesnt really seem like he has made an effort, last time he seen me was when i was 3.
how could ya do that?
if me and my missus broke up, theres no f**king way i could never see my son again, not even for a week!
let alone 20 years....
some things may be better left unchanged.
Sounds exactly like me dude.
Haven't seen my real dad for about 20 or so years and has had plenty of time to see me or meet me. Infact I found out he lived in mclaren on the lake while I was living in mclaren vale.
Only reason why I haven't made my effort to track him down is the guy who I call dad now has been a great father to me so I don't see why I should find someone who means nothig to me.
Everyone has their reasons why they don't want to meet their missing relative. I have my own reasons, you've got to make up your own mind and weigh out the pros and cons for it all.
Goodluck
Goodluck
that is exactly whats stopping me.
I can already too a full face helmet would sh!t me to tears on the track.
There are a few on eBay for $40 open face +$20 post which are all upto aussie standards. Just not sure on sizes, i'll rage if I get a helmet that is too big lol
na man, that will be done in like 3-4 weeks, along with hyrdo hand break, vs commo rear callipers
ecu display and a few other goodies...
i cant make it to the june 19 coz of a 40th, there isnt one in july, so the next one i can get to is aug 14 :ninja:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
