Not sure if non-FBers can see this or not, but check this out. Loved it.
http://www.facebook.com/home.php#!/vid...v=1218044052737
Yeah seen that plenty of times. Funny as. Reminds me of my Grandfather. He was a boxer in WW2 and he could still hit em hard before he died at 82yo.
  • Replies 14.2k
Troy i used to have BFG sports 235x45x17 they were a decent tyre
then i heard they were stopping that one or something cant remember this was 3 years ago
yeah old man pwned that noob
EDIT
are these sort of what you were thinking
EDIT
hahahah these are semi's
thanks matty, definitely good to be home. never been OS before, bit of culture shock for the first couple of days, but when you get used to the 32+ degrees and stupidly close to 100% humidity, its alright. stayed for 10 nights, just enough time to make me enjoy coming home.
yeah and more $$$
f**k it, ill keep sliding the 31, dont care what others say.
eventually it will more than likely come to an end, THEN ill worry about another set up.
Kye, organise a private day!
i cant say iv ever driven a CA, its just the thought of a 4 cyl makes me feel all dirty
Think you need to come for a drive in my car as well Craig, nothing dirty about a 4 cylinder champ....
ANYONE HERE WORK AT THE MINES OR RIGS?
Getting close to finishing my studies and need some hook ups.
Cheers
if i still worked at BHP I'd have been able to put u in contact with a HR manager... ;\
best bet is to get a copy of any certifications you have (such as forklift licences, heavy vehicle licences, tradie stuff) and forward it to the HR manager @ 55 Grenfell St, Adelaide, 5000 and make sure your cover letter is 100% awesome enough that they put u on file. They will eventually be turning OD into an open cut mine which will eventually be very labour intensive, I just don't know when its going to happen.
Other thing is, there are a few other natural resource companies that are based in SA like petratherm, they are small outfits now but just about all of them are projecting exponential growth once their mines/taps become operational, so I'd also be doing some research about the different companies around here. Some are based around ores but there are also LNG and thermal/solar/wind to consider too
Whats your trade?
-D
What sorta stuff you interested in Kye???
Hey mate, I'd really really like to get into mudlogging on a rig but I'm not overly fussed.
I'll be qualified in pretty much geoscience areas so I'll have to work around the geologists mainly.
Whats your trade?
-D
hey bud, I'll be qualified in mining exploration and diploma in geoscience.
I've got first hand information through an industry orientation lesson about a few places (mainly rig based) and all my info regarding PIRSA.
Also my girlfriends dad worked for Rio pretty high up too but I'm trying to attack this job hunting every which way I can through as many different contact as possible! Due to this stupid tax purposal, a lot of natural reasource companies have slow production till it's all sorted so getting in can take some time right now.
I've got petratherm on my list a long with beach petrolium. Hot rocks seem to be the way of the future but at the moment their only small areas in a huge industry at the moment.
Going to be busting out the resumes everywhere just seeing if anyones got direct contact so I can bypass all the crap along the way and hopfully snake a few people :)
cheers
