  • Replies 14.2k
oh and if any of the exec have commbank so i can deposit instantly!!
the account nominated on the form is the SAU:SA account, would be a bit suss if members of the exec were receiving payments into their accounts :blink:
I tell you what, ill fill a form in for you and pass it on next Wednesday, you just send payment now.
first unhappy customer ive ever heard of. fixed my R33 perfectly, no complaints from me. also sent a few friends to Allan through insurance and all were extremely satisfied. He has good communication while your car is there, good price and great workmanship.
another who is about to spray the Starlet is Joe from profinish near Morpowa. work seems great from other customers and is well equipped to just two people. The car will be back from their repair work next tues so ill know then how he is
VU,you actually had work done there or just a 'vibe' you got?
Yeah... I actually had work done there - front bumper of my old R33.
dont give him access, i need to delete the "Adrian is a wanker" thread first
Too late. He's going to see all the nasty stuff you said about him now :)
If your a member of a cams affiliated club, whats a 1yr cams license worth?
L2NS is $55 per year for CAMS Affiliated club member
L2S is $100 per year for CAMS Affiliated club member
:blink:
I just signed up for my L2S licence. Will be competing in the 2010 AWD Challenge. :(
L2NS is what you start off with isn't it?
Not necessarily.
Shane got his L2NS to compete in the rally for Clipsal. But I'm going straight for my L2S licence to compete in the AWD challenge (Time attacks and hillclimb events).
A L2NS licence entitles the competitor to compete in events such as observed section trials, touring assemblies, non-timed road events, motorkhanas, khanacross and drifting events up to International level.
A L2S licence entitles the holder to compete in L2NS events plus regularity trials up to National Championship level, single and multi-car speed events (not racing) up to International level, and touring road events that do not run over closed road sections. L2S licences are the most popular CAMS licence to hold.
More info here: http://www.cams.com.au/Development/Get%20I...ce%20Types.aspx
+1 for Joe, he painted my bodykit, loved his work.
+1 for All Type, my gf's brother works there, has doen work on my car, including re-fibreglassing my front bar and painting it, but his main job there is panel beating.
+1 for Hounslows, I have seen the spray job they did on Anthony's R32, very very nice.
Ive had work done by 4 different places throughout Adelaide, the only place I will touch now is Profinish, the work was waaaaaaaaay better than I could have hoped for.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
