  • Replies 14.2k
Dear **************,
your a f**kn puff the crank sold for less ,you are a week little boy hid,n behind your computer , do the world a favour and f**k off
- 6321kris 320523152698.jpgEnd time:06-May-10 19:09:29 AESTSeller:
Listing Status:This message was sent while the listing was closed.
I've copied the email to Ebay. See what they do with the guy now. My response to him was that if he was going to send abusive emails, he should at least learn grammar and some spelling first. :)
Ah geez, if only this wank knew who he was abusing. The difference between you Ruby and a keyboard warrior, is Ruby will travel interstate to knock on your door!
Thankfully I hadn't paid the $96 for it ... so there is no real loss. I had thought about a QLD holiday, if I HAD paid the $96. But right now I'm just amused at how 'fragile' this guy's temper is. Negative feedback obviously is rated up there with declaring war for this guy. :) I'll play nice and go thru the ebay avenues to get him a slap on the wrist for whatever its worth.
Unfortunately for you, I can't see ebay doing FA about it!
Yeah I know. Like I said, no money was lost in the end. Which is why I'll leave it at ebay. If they take it no further I'm not going to sook about it :(
If anyone wants a cheap GPS unit, Super Cheap (at Port Adelaide, not sure about the other stores) are selling the Nuvi 260 for $49!!!. Cash Cons are still flogging off these for $175 second hand :)
I paid like $300 for mine (twice ... yes I had two thanks for thieves) some 18 months ago. They're a good unit, so I've bought another one ;)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
