  • Replies 14.2k
Well. My poor R32 has developed a driveline problem. It seems the clutch wont disengage the gearbox fully. I drove down half of my street in 2nd gear with foot on the clutch. It crunches 90% of gearchanges, and to put it in 1st the car needs to be switched off, select gear, then start again. When you take off it shudders and makes a clunking sound. Been talking to Dave and he has suggested checking out the clutch fork, slave, and pivot.
Have you bled clutch correctly? Do it on a hoist (like I did) so you can see the amount of fork travel at the slave cylinder. And bleed it from ALL bled valves. My Stagea has 3.
:thumbsup:
I did bleed the clutch, albeit on axle stands, and it all seemed to be doing its job. I will have a look if I get time, but Ive got an appointment, need to finish a uni assignment thats due today and work. Cheers guys.
blokes just throwing it out there small cruise happening sat night at bunnings parafield 7pm just carpark to carpark deal anyones welcome should be a majority xr6t's but we get 1 or 3 skylines rock up so if u want a fair quick paced run sat night cum down and talk shit and say hi
Alot of SA people are going to the Kadina Show and Shine this weekend, so you might not get much of a response. And maybe dont include the meet location, unless you want unwanted visitors, and i dont just mean cops! :thumbsup:
easiest way to bleed nissan clutches is to have 4 hours and plenty of beer spare, or buy a 1pc braided line from master to slave and p1ss the balance block and damper pipe off. Most good workshops will follow the factory service manual and pressure bleed it with a vacuum device :thumbsup:
I had a similar issue, didn't crunch gears but was sticky as f**k. Clutch fork had spun on the thrust bearing and the slave was pushing the fork on an angle etc etc, it was really messy. It was all replaced before any serious dramas but frusterated the f**k out of me.
Quick Q:
Whats the main differences/advantage between R32 GTST front calipers and R33 GTST front calipers?
Is it simply the 32 is just for 280mm rotors and 33 is just for 297mm rotors. Any differences in piston sizes?
so found our new puppy after looking for a good month, bullmastiff x staffy.
only thing is, its in pt lincoln god dammit.
looks like im going for a drive next weekend
Congrats! Looks like a beautiful puppy. Please make sure you train and exercise it properly and love it dearly.
hahaha mastiff's get huge staffy is a medium dog
personally i wouldn't buy cross that's when you get temperament problems
Sorry Steve but I'm going to call bullshit on that statement.
I have volunteered at the Lonsdale RSPCA in the boarding section for over 18 months now where we have a minimum of 70 dogs every day and up to 120/130 dogs per day on long weekends. After looking after, walking, playing with, feeding and grooming 1000s of dogs I can tell you that temperament problems have nothing to do with cross breeding.
Dogs are the most loving and loyal creatures (to humans) on the planet. Temperament problems that can occur will usually be due to the humans that come in contact with the dog, its surroundings and everyday life, if the dog has been attacked before, or in some cases mental illness (just like humans have).
As someone who studied genetics I can tell you that 'pure bred' dogs have suffered from generations of in-breeding, usually grandfather & granddaughter mating, and IIRC in some breeds there are less than 50 variances in their genetic code, ie they are closer to extinction than the Panda Bear. I will need to search to provide a reference for that statement though. Cross breeds vary the genetics of the dog and are therefore likely to live longer and suffer less illness. I had all this info on my old C: drive which died so I'll have to search for the books again to elaborate further.
FYI
****WANTING TO BORROW****
Pair of NON-HID R34 headlight for regency, will swap my hid's for yours standard ones and when im off defect then swap them back and sure i can find a 6pack in it for you too.
Please get to back to me asap as regency is booked for the 22nd of june and my original headlight plan fell though
-lewis
0432 581 798
Mitch there should be something under the car, basically alittle toggle thing which u need to undo.
And Lewis I got non Xenon ones here u can borrow.
Edited by Luke_ENR34
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
