  • Replies 14.2k
While we're talking tyres, who wants to spot me $240 so I can get some replacement tyres for the AWDTC Time Attack next month?
:rofl2:
Doing my brake upgrade, paying the mortgage, and on one income is slowly killing me :D
I have JIC coilovers in the ass end of the 180,
And the locking tabs are bigger size then the fronts to lower it, the fronts are as per normal any other coilover locking tabs I've ever seen, so my c-spanners dont fit... I dont want to take a chisel and hammer to the locking tabs so does anyone know where I can purchase a set of spanners to suit a bigger locking tab? Looked on eBay, nothing...
I need to shlaaaam the ass end of the 180 yo
:D
Doing my brake upgrade, paying the mortgage, and on one income is slowly killing me :)
what pair of tyres will you be getting for $240
