  • Replies 14.2k
currently taking off the r32 gtr brake calipers from front of stagea, reinstall to r32 sedan, and
installing my wilwood racing kit
325mm brembo drilled rotors
adapter plates
braided lines
all bolts/hardware
added speedbleeders
wilwood 4-pot calipers
here is the exact one I bought, although he has added $100aus for shipping
(shipped in 2 packages, discs in one post, rest in another
http://cgi.ebay.com/ebaymotors/Big-Brake-K...sQ5fAccessories
looks like it fits S1 stagea, will confirm later
Jamming 3rd mid skid especially when the syncros are a bit shifty is hard thing to get the hang of. Might enquire with SARace what it would cost them to change the syncros on 1 - 4 maybe, otherwise deal with it haha. It is a z32 gearbox, might be worth doing. I'd like 1 - 3 straight cut gears :P
i just wanna do tandems with you again already :)
Random but i have finally shaved my head an number 2, no more loking like i am holding onto my hair. lol :)
Haha, welcome to the baldy club Shaun.......Carl & I don't have a say in the matter but Madaz shaves his head anyway just so he can gain entry into the exclusive club!! :P
So looking at a new phone and im looking at the HTC legend. Anyone heard anything about them or had use of one?? Don't mention iphone to me cause i can't stand apple stuff, even simple things like itunes is a load of wank....
The current top of the range Android phone currently available in Australia is the HTC Desire
Yep from what i've read thats right, but problem being that that phone is exclusive to telstra and be stuffed if im going with telstra...I just ordered the htc legend today should get it friday on a $49 cap plan with vodafone...I've watched some videos and read reports this morning on them and the legend is a very worthy phone all in its own right, and only just slightly less of a phone then the desire
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
