Kudos to Jap Import Spares
Picked up genuine tie rod end for S2 Stagea or R34 GTR for $95 each.
Another place wanted $175 second hand!!!
:P
Now I gotta rip the tie rods and brakes out tomorrow and fit the tie rods and R34 GTT brakes ... in time for the Time Attack on sunday.
  • Replies 14.2k
Just thought I would express my appreciation to my supervisor. He ordered me some new tools without me asking, and delivered them to me on the job site. He also delivered the good news that my new Subaru Forester will be arriving over the next few weeks, along with my new Dell Laptop.
What a champ!
oh, and my tax refund just turned up in my account :D
win!
Well I have decided I am going to go hop in the spa with a couple of beers .... so don't be surprised if you guys don't see me at Villi's tonight, as I may well decide I cbf getting out of the spa :)
And any Northies who 1) have my number and 2) know where I live, feel free to come over - there is plenty of beer and the spa holds 6 ppl :D
Hey Andrew I have a present for you ;) you will have to come in sometime and grab a coffee so I can give it to you!!!
Well I have decided I am going to go hop in the spa with a couple of beers .... so don't be surprised if you guys don't see me at Villi's tonight, as I may well decide I cbf getting out of the spa ;)
And any Northies who 1) have my number and 2) know where I live, feel free to come over - there is plenty of beer and the spa holds 6 ppl :)
if i didnt feel like a ranging homo for saying id happily join you, id come along :D
+ fart assing around with timing etc to ensure the mixtures are right and the timing is where it should be etc.
no once you start mucking around with timing thats a touch up tune and will be charged accordingly
for a AFR check all your doing is making sure @ WOT your AFR's are going high in the 12's to low 13's
will post up a pic late of my AFR run @ Jaustec need to scan it
EDIT
Chad did your clutch plate come today
anyone know the name of those crazy race driver toys that have the little man who makes the engine noise as you change up thru the gears, has a key to turn on, starts out subtle and gets radical as you shift up the little gear lever, its only about 6 inches tall or so ????????
